radio antenna reception on a sundance spa - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-19-2012, 03:26 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default radio antenna reception on a sundance spa
i have a sundance spa with a fm/cd/ipod receiver witch is a car/boat receiver and the radio reception is just okay
i was wondering if it is possible to ad something between the radio and antenna to get better reception
or if any of you now a very good antenna(car,boat or house), one that has very good reception
thanks everyone
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
Old 10-19-2012, 03:44 PM
Gibbonboy's Avatar
Gibbonboy Gibbonboy is offline
Vehicle: 2005 Ram 1500 Quad Cab
Rep:57
Gibbonboy will become famous soon enough
You could buy an antenna amplifier, might be better off just getting a better antenna. Is this outdoors? Terk makes a lot of indoor antennas, not sure how well they work. Check Amazon for antennas, a lot will depend on how/where you're going to mount it. Automotive antennas are generally designed to operate with a metal ground plane, like the sheet metal in the vehicle. I used to live in a very poor reception area, I had one like this:
http://www.ccrane.com/antennas/fm-an...x#.UIGrsG_A96A
Now I generally make my own antennas. I can customize them to the location where I'm putting them so they're less obtrusive. Just keep in mind that smaller antennas are always a compromise, comparing apples to apples, size does matter for antennas. Hope this helps.
"Just because I don't care, doesn't mean I don't understand." -Homer Simpson
Old 10-19-2012, 04:18 PM
crusher's Avatar
Rep:368
thanks
yes this is a outside spa
did this new ccrane antenna gave you better reception?
Old 10-19-2012, 05:30 PM
Rep:2929
what is the Brand of the radio receiver
it does make a difference
is the radio mounted in the hot tub? or just close ?
there are things that can be added to the radio to boost or amplify the signal range
like a 50 watt linear, these may be considered illegal
another good option is to set a 20 foot pole into the ground & put a good antenna on the top of it & run the antenna cable over to it, or just put the antenna on your roof
This type of antenna is called a BASE MOUNT ANTENNA
a word of caution, when you set up a CB Base Station & set up the proper antenna for it, it quickly becomes addicting, then the MODs start
Old 10-19-2012, 07:13 PM
crusher's Avatar
Rep:368
lol
the radio is mounted in the hot tub but i dont remember the brand,
i'll look and post back on monday when i'll be back to work,.
thanks for the help
i'll probably try buying a good antena and get it on top of my gazebo
Old 10-20-2012, 01:01 AM
Gibbonboy's Avatar
Rep:57
The C Crane FM antenna gets phenomenal reception, if you're not in a "fringe" area, it can be too much, you'll get multiple stations on frequency. Also, it has an "F" connector, most automotive radios have a "Motorola" connector, so you'd need an adapter.
Receive amplifiers are perfectly legal as long as they conform to FCC Part 15, which will be 99.9% of purchased electronics. Anything that transmits is more strictly regulated, you won't need to worry about that in your case.
Find the best outdoor-rated antenna you can afford, put it as high as you can, keep it in the clear away from large metal objects (and powerlines!), you'll be golden.
Old 10-20-2012, 11:15 PM
crusher's Avatar
Rep:368
that maybe my problem, my gazebo is made of metal so i'll try to get my new antenna away from it
Old 10-20-2012, 11:24 PM
Gibbonboy's Avatar
Rep:57
If the roof is all metal, you might get good results with an automotive antenna, as long as it's mounted right to the roof, and no part of it is below the edge. The metal roof will act as a pretty good ground plane. Otherwise, high as you can and away from metal.
Old 10-23-2012, 09:21 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
If the gazebo has a metal roof, it will make a good ground plane which is what an automotive 'Needs' to function. Gibbonboy knows want he's talking about here.
brad
Interested in one of my mods?
