Old 03-25-2013, 03:19 PM
Originally Posted by mrpatel View Post
Yes they are great! I got a killer deal on the for $215 as a pricing error. Thats why I pulled the other set of Hella's out. I got a piggy back style fuse, used the exisiting ground on the fender, and drilled a hole though the empty plate by the steering column. Let me know if you need more information. It seamed way easier and in my opion, the lights work better up high. No holes any where, except in the one block off plate. Andrew
WHAT?
$215 for the pair? Those are $399 retail.
$215 is so much lower than our cost too
Good find and good buy.
Old 03-25-2013, 03:21 PM
mrpatel mrpatel is offline
Vehicle: 2012 Ram Laramie 4X4
Color: True Blue Pearl
mrpatel is on a distinguished road
Yah, they should have been $450 CDN. He adjusted the price and honord the mis-placed sticker.
Old 04-02-2013, 04:38 PM
Thet's Avatar
Thet Thet is offline
Vehicle: 2013 Dodge Ram
Color: Gray
Rep:32
Thet is on a distinguished road
I wanna do this, but for the longest time, I wanted an external 4 mount. This may be a viable, cheaper option.
Old 04-03-2013, 02:44 AM
Thet's Avatar
Color: Gray
Rep:32
Sorry for the double post, but is it possible to mount 4 in there?
Old 04-03-2013, 06:33 AM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
You should be able too. I have two 4 inch round led lights on the bottom rail and with the bracket they fit perfectly between the grill slots. Mine are mounted to the bottom rail. If you put 4 you may have to mount 2 to the top rail. I don't think those will fit as well though. I think the top rail is closer to the grill opening which would cause your lights to be off centered and not shine through. I doubt it would work if you used 6 in round
Old 05-09-2013, 02:25 AM
Fidgetboy Fidgetboy is offline
Vehicle: 2011 Dodge Ram
Color: BLUE
Rep:22
Fidgetboy is on a distinguished road
I am having two 9 bulb led lights installed behind the grill tomorrow on my 2011. I want to wire mine into the high beams can anyone tell me which wire is the right one to tap into to trigger the relay? Thanks in advance. I will post pics after installed.
Old 05-09-2013, 10:20 AM
Fidgetboy, Id like to say I remember as I did this already, but the way I figured this out is I popped the headlight off and removed the dustcap behind the highs and you will be able to see the wire that goes to the high beam bulb.
Im trying to remember and I think it is the green/white wire.....BUT, pls double confirm by the method I told you and you will get it correct
Old 05-09-2013, 09:43 PM
dmac101 dmac101 is offline
Vehicle: 2012 dodge ram
Trim Level: laramie
Rep:39
dmac101 is on a distinguished road
going to be running to the city tomorrow nearest place for me to get stuff like this is about hour and a half away. so i need info asap. want to do this mod. so what exactly can i get behind the grill any 6 inch light from canadian tire or princess auto etc, any light will fit? they don't have to be slim lights? what size fits well 6 inch or 5 inch or 4? etc.
next question. regular halogen lights arnt to hot? would led be the better option. do led ones put out as much or more light output?
and what is better or more specifically what does what a flood pattern or the beam or whatever they were calling it.
thnks
Old 05-10-2013, 12:12 AM
Color: BLUE
Rep:22
Default Got my lights in today!!!
Got the lights installed today. Here are some pictures from the install. I will take a night time picture when it gets dark.
Old 05-10-2013, 02:15 AM
Color: BLUE
Rep:22
Default Night pictures.
Here a couple of night time pictures. You can definately see the difference between the two photos. I need to get out on the road and set them up properly.
