Old 10-20-2012, 06:30 PM
mechdogg2 mechdogg2 is offline
Vehicle: 2010 dodge ram 4x4
mechdogg2 is on a distinguished road
Default Back spacing
I have a 2010 ram 1500 4x4 with a leveling kit,was thinking of taking the factory 20's off and putting 295/70r17 on a 9 inch rim. Same hight as the factory 275/60 20 but an inch wider. What is the best back spacing so they wont rub but dont stick out to far?
Thanks
Old 10-22-2012, 03:39 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
You should be fine (outward fitment) with down to a 0 offset, which would be 4.5BS I believe. You don't want to go any higher than about +6 on the offset (for innner clearance)
That will give you just shy of 1/2 inch of more clearance on the inside between the tire and suspension. That should put the tire pretty much flush with the fender w/out flares.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 10-22-2012, 08:01 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
i do believe a +0 is a 5in backspace as my -24 are 4.5in backspace and my -12 that i had were 4.75in backspace, a +6 would be about 5.25 +12 would be 5.5 and +18 would be 5.75 atleast this is the case with 20's
Old 10-31-2012, 03:01 PM
thanks for the info
Old 11-01-2012, 03:59 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
You are correct, 0 offset on a 9" wheel does = 5" BS.
Your -24 should be 4" backspacing though.... assuming its a 9" wide wheel.
For a -24 offset wheel with 4.5" of backspacing you would need a 10" wide wheel.
backspacing, rim, tire
