Old 10-20-2012, 07:26 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
Default Sudden A/C problem on my 2012
Yesterday I went to get in my truck after starting it remotely and noticed that the A/C was not on. I always leave it on precisely because I use the remote start to cool the truck a little before I get in. Today I did some errands and every time I got back into the truck it had forgotten the A/C settings. I also notice that when I turn them back on it takes about 15 seconds before the A/C blows from the dash vents and not from the floor vents. Guess I have to take it in to be checked out. Anyone else seen this problem? I'm expecting the dealer to give me a hard time when he sees I have removed the radio and shifter bezels to paint and install a Lockpick, but all that was over 6 months ago and could not have had anything to do with this.
Old 10-20-2012, 08:39 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Doesn't the truck check the outside temperature and put the heat/air conditioning on? Maybe it wasnt hot enough out? I forget where I read what the temperature had to be.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 10-20-2012, 09:34 PM
Color: Mineral Gray
Rep:26
I've never heard this or seen it. It's always remembered the last setting and been on when I get in. Besides, this is Florida and it is still in the mid-80s here.
Old 10-21-2012, 04:20 AM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
Mid 70's in northern Florida haha but good luck with the A/C.
Lift 'em high because fat girls can't climb!
Old 10-21-2012, 04:23 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Mine checks and sees if I need heater or AC but its always on one or the other when I use remote start.
Old 10-21-2012, 11:03 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I know this might go against few here that say that pulling the battery connector of the battery will do nothing since all information is held in a cmos type memory and cannot get erased when removing the - pole on the battery, but If I was having that problem, I would pull the negative cable off the battery for a 1.2 hour and put it back on and see if it might reset something screwy in the system. JMO
Old 10-21-2012, 11:44 AM
Color: Mineral Gray
Rep:26
I was having just that thought yesterday and may try it today. Will be a hassle to reprogram everything from scratch (radio, garage door opener) but it could fix the issue and that's easier than a trip to the stealer.
Old 10-21-2012, 06:01 PM
Color: Mineral Gray
Rep:26
Disconnected the battery for about 3 hours and no difference. Funny thing is that I didn't lose the radio settings, BT pairing or station presets nor the garage door opener memory or EVIC memory. Either these things are stored in non-volatile memory or there is some kind of backup power supply for them.
Old 10-21-2012, 07:09 PM
Vehicle: .
Rep:4373
See thats what another member was saying, seems that on these new trucks the memory for everything is stored in some kind of cmos memory chip that cannot loose its info if the battery goes dead, and was also told the only way to reset the ECU was via the dealer. sort of sucks, cause if you had an idiot light on the dash, you could just reset it by pulling the battery - cable and you would reset everything. Not anymore LOL
Old 10-23-2012, 05:06 PM
Color: Mineral Gray
Rep:26
Got an appointment tomorrow to bring her into the dealer. Can't wait to see what they say.
