Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 10-20-2012, 08:33 PM
CB56 CB56 is offline
Vehicle: 2000 Dodge Ram 2500
Trim Level: Laramie SLT
CB56 is on a distinguished road
Default Turn signal problem
Hello, I have a fast flashing indicator when using the right signals. This usually means a burnt bulb. The front one was not flashing so I removed it. The bulb did not look bad. I tested the connector with a volt meter and have no power. I put everything back together and started pulling fuses one at a time at the box under the hood. The entire time I had the signal flashing and could hear the clicking. The clicking went back to normal and the bulb is flashing. The fuses that I had checked were good. Any help will be appreciated. Best, CB
