Old 10-21-2012, 08:46 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
TheBlackHemi; that was a perfect example of manual shifting for ArcticWhite. Hell, you were right at 90mph before you shifted to 4th. I'd say for ArcticWhite, easy horsepower boost when your baby kicks in to 4th......................100shot Nitrous baby! Your buddy's got boost and you'll have a boost!
Old 10-21-2012, 10:03 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
^^ I was thinking the same, add a small shot of nos.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 10-21-2012, 10:18 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Originally Posted by TheBlackHemi View Post
Shift in manual and hold the shifter all the way to the left and you will some what powershift all the way thru 1,2,2ndprime, and then 3rd. Which on leaves you really one time to shift at 55-5600 rpm into 4th....which will drop you back down to 4k something rpms.
You're saying physically hold the shifter to the left and it'll shift through the gears or are you bumping it over for each gear change?
Traction control on or off?
Old 10-21-2012, 06:49 PM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
A tune will really help us by adding some HP, lowering or removing torque management and raising shift points so when you hit the next gear, your RPMs don't drop as much.
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 10-22-2012, 02:10 AM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Yeah Physically hold it to your left and it will shift for you all the way through 1st,2nd,2nd prime, then 3rd....you just have to shift into 4th. You can also just leave it in 3rd and it will do the same but to me it pulls harder when you hold it to the left, especially the shift from 1st to 2nd. Just try it out and you'll see what I'm talking about. As long as you got good tires I would tire traction off but either way with it on or off I've actuall y had it engage traction control for whatever reason. Hopefully will have our trucks tuned by next month and really get to start to move. I've got my trinity in hand just waiting on the release....its been a 1 1/2 years waiting.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 10-22-2012, 04:58 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I'm gonna try this today. I have always started in 2nd, let it shift by itself, and then shift to 2nd prime.
Old 10-22-2012, 09:23 AM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
Interesting...who figured out that little trick?
Just to clarify...drop it into 1st and hold it left, it'll up shift through 3rd then manually click it into 4th?
Old 10-22-2012, 09:35 AM
Gantman's Avatar
Rep:974
Thank you guys for the pointer on the hold to the left through prime. Can't wait to try that out instead of the bump through each gear method.
Old 10-22-2012, 09:36 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm curious as to what that does. I don't see how doing that would change anything, I'd think it'd just shift like normal.
I can't try it as I don't have a console shift and this is JMO but I think it might just be perception...?
I do know the 3rd gen guys would hold it down a gear to keep if from up shifting through the gates, but I don't think that's what this is, unless I misunderstood.
Sean
Old 10-22-2012, 01:07 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
If you watch the video, you will see it's not perception. Watch the rpm's, not the speedometer and you will see the difference....especially 2nd prime.
