Dodge Ram Decals
Old 10-21-2012, 12:06 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Default I need help with wheels :(
I am looking for a set of 22's to put on my CC sport. I have it dropped with 2/4 bell tech kit so I don't know if 305/40/22 will work or rub to much. I want a nice set of 5 spoke design with a lip. Something like the Boss 335 or so. I don't want anything that is black and chrome mixed. I will most likely go with chrome I kinda like the look of everything blacked out except wheels. I want to stay with 22's to try and keep the performance up.
Old 10-21-2012, 12:27 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
My 305/40/22's just barely rub the sway bar at full lock...it's a bigger diameter Hellwig bar though. Just watch your backspacing and you'll be fine with that drop.
I play with this all the time when figuring out wheel stuff.
http://www.rimsntires.com/specs.jsp
Old 10-21-2012, 06:52 PM
MOFOGO's Avatar
MOFOGO MOFOGO is offline
Vehicle: 2012 Dodge Ram RCSB
Rep:38
MOFOGO is on a distinguished road
I went with Liquid Metal Lithium wheels in 20"x9", they do make this same wheel in 22". I like it because you don't see it everywhere. You should see the quality of the chrome in person. Got mine from DiscountTire on-line.
Old 10-23-2012, 06:14 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
If you can find a 22" wheel in a 9" width that you like I would go that route, or if you go 10", get a wheel with a little less offset than the SRT's (mine are +25.4). It's the width and/or the offset of the wheel that's going to cause you to rub a little on the swaybar at full-lock. The size of the tire is'nt as critical, as I've read numerous posts of guys with SRT's rubbing with 285/45's, 305/40's, and 305/45's (which is what I have). You also could run 1/4" or 5mm spacers, or just do what I do, which is not turn the wheel to the full-lock position. Good luck with your choice!
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 10-23-2012, 06:20 PM
RAM EM's Avatar
Color: Grey
Rep:195
Also, I have seen pics of your truck and it looks slightly lower than a 2/4, so I would be more concerned about tire diameter. I would stay away from 305/45's, as they are about the same height as the OEM tires, and I could see you bottoming out easily. I would go with a 305/40 or 285/45. JMO...
Old 10-23-2012, 06:43 PM
Rep:47
I think 285/40/22 is what I'll be going with. I found a set I want that are 9 inches wide.
Old 10-25-2012, 02:45 PM
TSINND's Avatar
TSINND TSINND is offline
Vehicle: 2014 Ram 1500
Rep:28
TSINND is on a distinguished road
I would do 285 45 22, 40 will look to small unless you slam it
Old 10-25-2012, 05:09 PM
RAM EM's Avatar
Color: Grey
Rep:195
285/40/22 is about 31.1". 285/45/22 is about 32.2". 305/40/22 is about 31.7". 305/45/22 is about 32.8". OEM 275/60/20 is 33". I agree that 285/40 would look too small. My pick for your truck, based on your pics, would be a 305/40/22 w/ 10" wheel, or 285/45/22 w/ 9" wheel. JMO.
Old 10-26-2012, 09:42 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
I had 285/40s on my srt 22s on my 05 and it was dropped 5/6... And still had a little gap. Look for it in my avatar...
I'll run 305/40s w my 2012 and belltech set up
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 11-04-2012, 10:34 PM
thmupr thmupr is offline
Vehicle: 2014 Ram Sport
Rep:12
thmupr is on a distinguished road
Check out my old thread from when I lowered mine...
http://www.ramforumz.com/showthread.php?t=103543
Menzari wheels... Lots of lip and I'm running 305's. Only rub is when I turn to full lock I get a little tire to sway bar rub.
