ZDOG
Old 10-21-2012, 03:04 AM
ArcticWhite ArcticWhite is offline
Vehicle: 2005 Dodge Ram
Rep:169
ArcticWhite has a spectacular aura aboutArcticWhite has a spectacular aura about
Default Question on 2012 ram ECM swap
I have a 2012 ram. I have a few questions on how the engine management is set up:
1. Does it have separate engine and tranny computers, or does ECM control both the engine and tranny?
2. If I purchase another 2012 ECM (say out of a wrecked 2012) would it be a direct plug and play? Is there anything programmed into the ecu that would prevent an ecu swap?
Has anyone done an ecu swap on a 2011 or 2012 without issue???
Thanks!
Old 10-21-2012, 09:51 AM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
just curious as to why u want to do this ive heard of others doin it for the 09 10 so they could use a programer but i think there is one available now for 11 12
Old 10-21-2012, 09:54 AM
Resident Technician
Rep:1911
The engine and trans are controlled by a common computer called the Powertrain Control Module. They must be programmedwith the VIN and SKIM code before they will work. I'm not 100 % sure but I don't think you can program them more than once.
Old 10-21-2012, 11:09 AM
Rep:169
So how does one go about getting a replacement PCM? Can the dealer program a new one? Does it have to come from dodge programmed?
Old 10-21-2012, 11:31 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
What's the reason for the swap?
If just for tuning then programmers are literally just weeks away.
Old 10-21-2012, 01:45 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:74
ShiftJockey will become famous soon enough
Yup, I'm curious as well.
Michael
2014 BIG HORN CREW
6.4L HEMI
Old 10-21-2012, 03:37 PM
Resident Technician
Rep:1911
You can buy one from the dealer and no, it doesn't come programmed. That has to be done by the dealer or someone with a scan tool that has that capability.
