MOPAR DECALS
Old 10-14-2012, 04:55 PM
jwj99 jwj99 is offline
Vehicle: 1994
jwj99 is on a distinguished road
Default Empty hole in valve cover, what is it????
My sons friend recently got a 94 1/2 ton 4X4 with 5.2 engine. We have been doing standard tune-up, i.e. plugs, wires, pcv valve, rotar, and cap. while under the hood I noticed an opening on the drivers side valve cover and can not figure what should be in it. It is almost the size of a quarter plus/minus. We replaced the pcv valve on the passenger side. Any help identifying what the hole is for would be a great help.
thanks
Old 10-14-2012, 05:31 PM
Rep:2875
a lot of the time, the PCV valve can go into either valve cover, depending on different engine options
the hole not used for the PCV valve, usually just gets a rubber plug in it
i have seen some people put in 2 pvc valves, run them to a T fitting & then to either the air cleaner or to the intake manifold
engine specs
http://dodgeram.org/tech/gas/specs/5_2v8.htm
Old 10-14-2012, 09:46 PM
Vehicle: 1994
I thought about plugging, just have to find a large plug. The hole is to large for a pcv valve.
Old 10-22-2012, 01:47 AM
rboozer rboozer is offline
Vehicle: 1997 dodge ram
Trim Level: laramie
rboozer is on a distinguished road
Might B for an OIL BREATHER
Old 10-22-2012, 02:06 AM
Rep:2875
first a grommet goes into the hole, then the plug or PVC valve
Old 10-22-2012, 08:09 AM
Rep:1388
If there is a pcv valve on the opposite side of the engine, it is likely a breather. The engine sucks in air from one valve cover and evacuates the pressure on the opposite valve cover(pcv valve). It should not be plugged, and should be filtered. Can run a hose from it to the intake(filtered side) or use a small breather cap.
