Old 10-22-2012, 02:28 AM
dodgeram02's Avatar
dodgeram02 dodgeram02 is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Rep:59
dodgeram02 will become famous soon enough
Default 2011 high beams?
is there a kit i can buy, or can somebody tell me how i can get my fogs and dims to stay on with my brights. i was told that when u turn ur brights on it grounds out ur dims and fogs thru a fuse or a relay. and that i could just break off that tab that grounds it out. would this work? and is it safe? somebody please help as my headlights suck. im going to get new bulbs but want to do this first. thanks. truck s a 2011 5.7 hemi
"I dont lie to my wife about my truck...I dont lie to my truck about my wife, they both know, no matter how good they treat me I'm still going to get on the other one"
Old 10-22-2012, 03:40 PM
Rep:1909
Whoever told you that has no idea what they're talking about. Power is pulse width modulated from the TIPM to the fog lamps. There is no relay involved. In order to have them on at all times, you would need an alternate power source and method of switching.
Old 10-23-2012, 01:41 AM
dodgeram02's Avatar
Rep:59
then why the fogs shut off when the brights come on. thats why i thought it would be relay, getttng grounded out or whatever like a toggle switch would. is there anyway could run a jumper wire from the positive off the brights to the positive of the fogs. then when the brights come on and the dims/ fogs go off the fogs would still be power. and it shouldnt over heat as long as the jumper is the same size as the headlight and fog light wires. this should work for your dims as well, except you would never be able to turn them off if your brights was on. would this wrk? thanks
Old 10-23-2012, 08:53 AM
Rep:1909
It's your truck and you can try anything you want. In theory, it would work but it's possible that it could set a code in the TIPM for a short to voltage in the fog lamp circuit.
Old 10-23-2012, 10:58 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
25 bucks and 10 minutes to install...problem solved.
http://www.ebay.com/itm/150552936567...567%26_rdc%3D1
Old 10-23-2012, 11:42 PM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:25
dig is on a distinguished road
Default Kit
Hay: Thanks I just order this kit. been looking for something like this.
Old 10-24-2012, 12:58 AM
dodgeram02's Avatar
Rep:59
but will that harness says it works for your fogs and brights. i want to be able to have my dims on too.
