engine removal???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 10-22-2012, 07:09 AM
roadstar30 roadstar30 is offline
Vehicle: 2003 2500 dodge ram
roadstar30 is on a distinguished road
Default engine removal????
Ok i am in the process of removing the engine from my ram 2500. 5.7 hemi with spun bearing!!!!! cause i knew you where going to ask!!!
I have a few questions that you might be able too help with,
I just bought the removal part 8984b to hook to the engine since i really didnt see anywhere to hook up a chain tight enough too get the puller in there and ge enough lift with out hitting the cowl.
so should i also put a jack under the trans and lower it in the rear while lifting and removing engine??? it doent say it in manual but i thught i read it somewhere.????
Old 10-22-2012, 08:14 AM
Resident Technician
Rep:1915
I don't use a jack under the trans when I pull these engines but you may as well because you'll need it when you reinstall the engine.
