Kickdown problem? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-24-2012, 11:42 PM
BigZach's Avatar
BigZach BigZach is offline
Vehicle: 1998 Dodge Ram Sport
Color: Forest Green Metallic
BigZach is on a distinguished road
Does Sonnax sell a kit with every part you just said? Would you recommended just buying that upgraded servo?
Old 10-25-2012, 11:58 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
I know that Sonnax sells what they call the "Sure Cure" kit, it includes a throttle valve, 4 spool switch valve, pressure regulator, and manual valve along with some other valves. It might be cheaper to buy the sure cure kit and the front servo kit, use what you need and sell the rest on ebay.
I forgot to mention the 4-spool switch valve, this valves helps eliminate lockup shudder and helps with converter fluid flow to keep the converter from overheating. Anyways the things that I usually replace on builds other than the clutches, seals, bearings, bushings, and so on are as listed:
a. 4-Spool Switch Valve (Note that some valve bodies aren't 4-spool)
b. Manual Valve
c. Pressure Regulator Valve
d. Throttle valve (I replace this because with the RH series, shift points are set hydraulically not electronically) I also like having a steel tip plunger instead of the stock aluminum tip.
e. Front Servo Assembly
f. Accumulator Piston (Depends...)
It's an expensive list (relative to the money in my pocket) but you basically bullet proof the transmission and correct so many issues.
Old 10-25-2012, 10:09 PM
BigZach's Avatar
Thanks a lot. You really helped me out with all this. I'll definitely get that kit and the servo when I get the chance.
Old 10-29-2012, 01:21 PM
ramvan2500's Avatar
Rep:141
Not a problem, afterall that is what I am here for. And sorry for the late response, It's very difficult for me to get online sometimes living out in the middle of no mans land.
