Wheel size help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-22-2012, 09:48 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Default Wheel size help
I am trying to find a cheap set of wheels for winter driving and have found these. http://www.tirerack.com/wheels/Wheel...All&sort=Price Is there any reason why these wont fit on my express?
Thanks in advance!
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 10-23-2012, 04:27 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Well they will fit, but they will stick out about 30mm (1.25") further than the stock wheels. That will put some of the tread just outside the fender(depending on tire width) which I think that you would want to avoid in the winter to keep sand,salt and ice off the side of the truck.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 10-23-2012, 07:14 PM
Rep:173
Thanks! I definitely don't want that
I would be getting 265/70 r17, so I am guessing these will stick out. What is the rim size that I need for them to not stick out?
Old 10-23-2012, 07:58 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
You'd have to get a wheel that is a 7" backspace as factory wheels are 5.75", which won't work because youdbrub all over you suspension of u could even get them on ur truck. Ur best bet would be get some smaller tires or fender flares
sales@revelperformance.com
Old 10-24-2012, 02:54 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:80
If you find a wheel that you like thats 9" wide I would keep the offset in the positive ( 0 to +20mm) (5" - 5.75" backspacing) and if you find a set that are 8" wide I would look for an offset between +6mm and -12mm (4" - 4.75" backspacing) (you can go higher but it would look funny sunken in)
Hope that helps a little.
That will keep you at stock position on the high side and about flush with the fender on the low side. You should still be inside the fender with those tires so you wont have to worry about spraying the side of your truck with sand and salt.
Old 10-24-2012, 03:59 PM
Rep:173
Thanks! That helps a lot!
