Old 10-23-2012, 01:38 AM
HIstateRam HIstateRam is offline
Vehicle: 2012 Dodge Ram Outdoorsman
Trim Level: 1500 Outdoorsman
HIstateRam is on a distinguished road
Default 2012 2wd ram 1500 question???
New to this forum and I have a 2wd 2012 dodge ram 1500. Just wondering, is there any level kits for my model truck? Where can I get it and how much inches does it lift it? What's the maximum size tires I can put with that level kit? I was planning to put 16x10 rims with 4" back spacing btw. Feel free to post pics of this set u. Can 16" rims fit on my car btw because I know my stocks is 17"? Thanks
Old 10-23-2012, 02:13 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I think even the base truck has 17's. might have clearance issues with the brakes with 16's, although I'm not sure.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 10-23-2012, 02:30 AM
Tubbs1 Tubbs1 is offline
Vehicle: 2012 RAM Hemi Crew Cab
Trim Level: RT
Color: Deep Cherry Red
Rep:31
Tubbs1 is on a distinguished road
Auto anything has them and so does fat bobs garage, both are Dot com's. You can only lift the 2012 2wd, 1.5 inches in the front to prevent it jacking up the geometry of the front end. This will make the truck look level minus a half inch. With the lift you can get a set of 35's max under there and you will have to cut the inner wheel well to keep it from rubbing. As far as the 16,s goes you cant do it the rim will not fit the rotor caliper setup on the truck. I hope this helps.
