Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
United Radio
Old 10-11-2012, 01:18 PM
Jmac86201's Avatar
Jmac86201 Jmac86201 is offline
Trim Level: Grey
Color: Grey
Rep:15
Jmac86201 is on a distinguished road
Default Chrysler Recall M34
Just got an email saying that starting in the beginning of November Recall M34 will be issued in the 4th generation trucks. It states that the rear axle pinion nut may loosen due to a lack of adhesive. if it loosens the axle can lock up and cause a loss of vehicle control and or crash with little warning. Dealers will install a Pinion nut Retainer to correct this concern.
Just wanted to make sure everyone was aware of an up and coming recall.
Old 10-11-2012, 05:02 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Here is more info I posted earlier:
http://www.ramforumz.com/showthread.php?t=123385
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 10-17-2012, 08:49 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Smile
Thanks pal, I heard of it but couldn't find it in google. Hence the new ram I saw w/ a dangling drive shaft on the side of the L.I.E. a few months back! LOL! & people were calling me paranoid on here. I think intelligent is more like it. Things just don't break for no damn reason!
Old 10-19-2012, 05:52 PM
sanddperformance sanddperformance is offline
Banned - Unauthorized Commercial Sales
sanddperformance is on a distinguished road
cool thanks for the info
Old 10-19-2012, 05:58 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Good info bud.
I believe this is the actual word from AllPar.
Chrysler recalling pickups
Posted on October 8th, 2012 • by Bill Cawthon
Chrysler is recalling certain model year 2009-2010, Ram 1500 and Dodge Dakota trucks, manufactured from July 1, 2009, through November 30, 2009, because a rear axle pinion nut may loosen due to a lack of adhesive.
Chrysler will notify owners, and dealers will install a pinion nut retainer, free of charge. The recall is expected to begin in November 2012. Owners may contact Chrysler at 1-800-247-9753.
Chrysler’s recall campaign number is M34. Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
NHTSA CAMPAIGN ID Number: 12V474000 NHTSA Action Number: PE12021
Summary: The Office of Defects Investigation has received 12 complaints alleging rear differential failures resulting in rear wheel lock-up in model year (MY) 2009 through 2010 Dodge Ram 1500 pickup trucks. The complaints allege failures at various speeds with eight of the incidents reporting failures at speeds of 35 mph or greater. Four of the complaints involving higher speed incidents allege that the failure resulted in a loss of control (e.g., vehicle spin, skid or yaw), including one resulting in a crash into a concrete barrier. One complaint reports that the failure was caused by loosening of the rear differential pinion nut. Most of the complaints allege that the failure resulted in drive shaft failure including one that reported the detached shaft end pu
The Office of Defects Investigation has received 12 complaints alleging rear differential failures resulting in rear wheel lock-up in model year (MY) 2009 through 2010 Dodge Ram 1500 pickup trucks. The complaints allege failures at various speeds with eight of the incidents reporting failures at speeds of 35 mph or greater. Four of the complaints involving higher speed incidents allege that the failure resulted in a loss of control (e.g., vehicle spin, skid or yaw), including one resulting in a crash into a concrete barrier. One complaint reports that the failure was caused by loosening of the rear differential pinion nut. Most of the complaints allege that the failure resulted in drive shaft failure including one that reported the detached shaft end punctured the fuel tank. A Preliminary Evaluation has been opened to assess the scope, frequency and potential safety consequences of the alleged defect.
Old 12-10-2012, 12:50 PM
merbert merbert is offline
Vehicle: 2010 Dodge Ram 1500 Crew
merbert is on a distinguished road
I took my truck in for an oil change and they told me there was a recall on it. Then I learn that the part is not available until early next year.
Old 12-16-2012, 08:08 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2008
For anyone who's truck is effected by this recall the information is now in the system and you can now check your VIN to see if you fall under the recall.
https://www.moparownercenter.com/oc/...nersLogin.aspx
That is a good place to go. Also you can call your dealer with your VIN and they will be able to check for you.
Chrome... in moderation.
