Old 11-07-2012, 05:32 PM
Hovenator's Avatar
Hovenator Hovenator is offline
Vehicle: 2012 Dodge Ram 1500 CC 4x4
Rep:31
Hovenator is on a distinguished road
Do you need open top spacers so the valve has a place to fit in the top of the coil/spacer?
Old 11-07-2012, 05:40 PM
sebber sebber is offline
Vehicle: 2014 Ram 3500
Rep:14
sebber is on a distinguished road
The kit comes with hard plastic spacers to protect the top of the bag
2012: 2012 Ram 1500/ RV:2012 Palomino S17
2013: 2012 Ram 2500/ RV:2013 Denali BH311
2014: 2014 Ram 3500/ RV:2014 Sabre QSIK35
A truck a year keeps the doctor away!
Old 11-07-2012, 08:04 PM
Evanrude's Avatar
Evanrude Evanrude is offline
Vehicle: 2012 RAM 1500
Trim Level: SLT w/Big Horn pkg
Color: Mineral Gray
Rep:14
Evanrude is on a distinguished road
Yep, all you have to do is remember to put the spacer in place before you hook up the line .
Old 11-08-2012, 01:28 PM
06Stang's Avatar
06Stang 06Stang is offline
Vehicle: 2014 RAM 1500 Sport
Color: Granite
Rep:40
06Stang is on a distinguished road
For a lift kit, yes.
Haha I did the same thing with the first one.
Chrysler Jeep Accessories Tech
Old 11-11-2012, 02:19 AM
ashman82 ashman82 is offline
Vehicle: 2011 dodge ram 1500 outdoorsma
Trim Level: outdoorsman
Color: hunter green
ashman82 is on a distinguished road
the air bags are easy to install. i have done a set of airlift 1000 and i have done the firestone ones. i put the firestone in my truck and i like them probably better. the firestone have push to connect airfitting on each back, the airlift has just a barbed fitting on the top of it. i have an oudoorsman also and the dealer told me i have updated suspension i belive all it is that they have a heavier duty shocks on the rear.
Old 11-20-2013, 07:48 AM
Samuel- Samuel- is offline
Vehicle: 2012 Ram ST
Samuel- is on a distinguished road
Originally Posted by thebaldguy View Post
I couldn't get a good shot of the 1/2 inch tube under the truck.
I mounted the valves on on each side of the hitch.
and then the side view...
That's slick, I dig it.
Old 11-25-2013, 09:42 AM
About to pull the trigger on air lift, and front leveling kit. I want to add a front 2.5 or 3 inch leveling kit. Will the airlift add enough to get me back level when I tow (around 6,000 lbs) , or do I need rear spacers also?
Old 11-25-2013, 10:29 AM
audio1der audio1der is offline
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
^ Good question. Mine gave a bit of extra height but if you want to get back to level with a fair load on the tongue you may still have a bit of sag.
This setup is SO easy to install and use, it;'s worth every penny.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 11-25-2013, 12:03 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
The Airlifts aren't designed to lift the back end of the truck at all. You might see about half an inch of lift or so if you fully inflate them without any load. But I wouldn't count on it. Their design is to reduce sag by pushing outwards on the coils making it harder for them to compress.
To level the front of your truck you don't want to go higher than a 2.5" (or 2.8" with Bilsteins). 3" will start giving you problems with CV shaft and control arm angles.
Old 11-25-2013, 12:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^exactly what he said. You won't get lift out of the airlift kit, just less sag.
All 4th gen v8 ram 1500's have the transmission cooler and same suspension(obviously some differences between models/trims). But there is no "upgraded" suspension, and the tow package doesn't add trans cooler(since it's included in the base models). I think tow package now only includes the hitch and the electronic brake controller. Even the wiring for the trailer hookups is included in the base models now.
Sean
