Air Lift 1000 Kit - Page 9 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 12-23-2013, 09:26 PM
MrPiper's Avatar
MrPiper MrPiper is offline
Vehicle: 2012 Ram 1500 Bighorn
Trim Level: 1500 Bighorn
Rep:54
MrPiper will become famous soon enough
Originally Posted by sunny1881 View Post
What Im not seeing answered here is how it rides when towing? I am towing 8k lbs about once a month. I assume they meet the purpose of leveling the rear so there is no sag but how about the feel during towing? Also and recomendations on sweet spot for this amount of weight being towed?
The ride and safety while towing is the entire reason to install the AL1000. I put it in myself in about an hour and a half by putting the bags in through the springs and routing the air lines through the frame to the rear bumper. I chose to use 1 air nipple instead of two because I don't ever carry a lopsided load.
My camper weights just under 7,000 lbs. with a tongue weight of around 680 lbs. I use a standard weight distributing hitch (WDH). My truck is a 2012 1500 hemi with 3.92 LS rear.
Without the AL1000 I have a SIGNIFICANT sag of almost 3 inches! The ride is less safe because it means less weight on the front wheels so less safe steering. My break chains almost touched the ground.
After the AL 1000, the trailer and truck are level. The ride feels like there is not a trailer attached. I really could not be more pleased with what this simple system does for less than $100.
I air up to 35psi before I hook up then let the air out until it's level. It usually ends up around 30 psi. When not towing, I run 5psi. The feel is about the same with as without the trailer with those settings.
I hope that is some help.
Old 12-26-2013, 06:22 PM
sunny1881 sunny1881 is offline
Vehicle: 2015 Power Wagon CC 6.4L Hemi
Trim Level: Power Wagon
Color: Blue
sunny1881 is on a distinguished road
^^^That helps, thanks! I ordered yesterday from www.rockauto.com they had the best price I found in my small search.
Old 12-27-2013, 02:18 AM
DodgeV10 DodgeV10 is offline
Vehicle: 2015 Dodge Ram 2500HD
DodgeV10 is on a distinguished road
Question? With the air bags having there own fill port. Would that improve the ride since air can't travel between the other like on a hard turn? Or would it matter? Is there an advantage over having a single fill port for the air bags? Pros? Cons?
Old 12-27-2013, 11:28 AM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
Some folks like to be able to fill the bags independently to help level a load from side to side. The kit comes with a plastic 'T' to tie them together which I used. For towing I find it better to keep them at the same pressure. YMMV.
FWIW I bought Timbren SES "springs" before I even picked up my trailer. I didn't want to mess around with an air system. The first time we towed (7K lbs, 700lb tongue) it was like riding with NO rear suspension. We felt every crack in the road; bumps nearly threw us out of our seats. I took them out and sold them immediately. Replaced them with the Airlift 1000 and WOW. Soooooooooo glad I did. It's smooth both when pulling and empty and easy to use. Even with the rear of our truck lowered 2" now(it was stock with the SES), the Airlift works great and is super comfortable.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 12-29-2013, 01:40 AM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
You would be better off leaving them separated for handling.
