Old 10-23-2012, 11:07 AM
Mikeaob's Avatar
Mikeaob Mikeaob is offline
Vehicle: 2012 Ram Express
Mikeaob is on a distinguished road
Default Painting Headlight housing Q's
I have seen some of the members in here "baking" the headlights and painting the interior chrome housing and I want to do this but had a couple Q's
1. my primary concern is resealing the housing. Is this hard ? and those of you that did this did you get moisture in the assembly.
2. Brightness - I drive home at night everyday in the winter will this affect the brightness of the light reflected ? I do plan to switch to Sylvania Ultravision bulbs or even the ZXE <-- (input is appreciated on that also)
Lastly I am thinking about the VHT spray to tint my rear lights (brakes and 3rd) any experience with that ? I will be adding a led light bar below the tailgate..
Old 10-23-2012, 11:51 AM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
To reseal it, remove all of the old stuff that was in there before, you'll have to heat it up a couple times to get it all off, then use butyl tape i believe to seal it all up, i didn't get moisture when i did my first set so you should be fine if you just are careful
if your painting your headlights though, don't paint the entire thing or else it will destroy your light output, only paint the outer bezel like i did here:
Old 10-23-2012, 11:57 AM
Mikeaob's Avatar
Awesome ! it looks so much better.. Thanks for the info. I will look up butyl tape .. Never used it before. I was thinking of a silicone of some sort ..
Old 10-23-2012, 12:54 PM
4x4Hemi's Avatar
Rep:172
I used silicone and RTV on that set and it sealed up, but it was a little more difficult, butyl tape is neater and easier silicone looked bad on the outside but it works
Old 10-25-2012, 05:35 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Did you just leave the amber reflector out on the turn signal? That looks SO much better!
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 10-30-2012, 10:39 PM
emazz104 emazz104 is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: 4x4 Sport
emazz104 is on a distinguished road
I did the same thing on my Subaru. I was able to just re-bake them to re-seal them, nothing else was added. They held fine.
If you do plan on painting them, take the above advice and don't paint the reflectors. Unless you retrofit projectors in them, you will never seen at night again with the reflectors painted.
If you want to paint the turn signal portion on the other hand, you can still make them just as bright (if not brighter) with LEDs.
They make chrome bulbs that still light up amber, but they are fairly dim. If you get LEDs that would also clear it so there won't be any amber at all, but they're not cheap and you need resistors.
Old 10-30-2012, 11:39 PM
4x4Hemi's Avatar
Rep:172
Sorry took so long i missed your reply! haha yep i did just leave it out, and i put in an amber bulb to make it legal
i put projectors in these ones this week. you can paint it all if you want then, and i put led switchbacks in em to
Old 10-31-2012, 04:17 PM
Hovenator's Avatar
Hovenator Hovenator is offline
Vehicle: 2012 Dodge Ram 1500 CC 4x4
Rep:31
Hovenator is on a distinguished road
Those look sweet! Where did you get the projectors from?
Old 11-01-2012, 08:05 PM
With projectors, but reflectors won't work if they're painted, if that's what you're referring to.
The retrofit looks great though, I really want one for my sled, but the car or truck should come first haha.
theretrofitsource.com is probably the most popular place.
Old 11-02-2012, 12:30 AM
4x4Hemi's Avatar
Rep:172
Yeah hes right, you need to have projectors to paint it all for sure.
Bought them from retroshop dot us. he runs a good site and helped me out with all my questions
