Old 10-23-2012, 07:18 PM
jojo77 jojo77 is offline
Vehicle: 2001 ram 4x4
Trim Level: sport
jojo77 is on a distinguished road
Default lacking power
Hi, I have an 01 1500 4x4 5.2L with 160000 miles. Truck really seems to lack power and milage. I tow a 17 ft aluminum fishn boat and feels like a 30 ft camper. I,ve changed cap rotor plugs and wires new cat and coolant sensor. 9mpg sucks any help is appreciated
Old 10-23-2012, 07:45 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
3 things which I've had good success with for mileage and power have been as follows. 1. test fuel pressure at the rail port the higher the better above 35 and below 40 PSI. 2 buy your 02 sensors from Chrysler using your VIN. and 3rd, replace your air filter.
Old 10-23-2012, 10:25 PM
Goatboy's Avatar
Goatboy Goatboy is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Economy
Goatboy is on a distinguished road
did you do the throttle cable fix? Helps for power but not mpg.
Trinity Dairy & Pack Goats http://trinitydairygoatfarms.webs.com http://trinitypackgoats.webs.com
Old 10-24-2012, 05:44 AM
Trim Level: sport
I've got a new air filter in,even ran without one without much improvement. As far as the throttle cable trick don't think that's it . Any little hill even at 2500 rpm and truck still feels like a 4 banger.
Old 10-24-2012, 08:19 AM
Rep:1890
Considering you have a high mileage 5.2, you might want to check your compression and see if the numbers are down. It's possible this engine needs an overhaul and if this is the case, now would be a great time to go with a bigger bump stick and do a little port work to the heads. Also, what gear does the rear end have?
Old 10-24-2012, 10:52 AM
Trim Level: sport
355 for gears also have 285/75/16 on. Thought about trying 265' s since orignal size is supposed to be 245
Old 10-24-2012, 11:10 AM
Rep:1890
Bingo. That's definitely robbing you of some power. I would say your options are to go back to stock size tires, beef up the engine, or swap over to 3.92 gears.
