Old 10-24-2012, 01:52 AM
Exxzaust's Avatar
Exxzaust Exxzaust is offline
Vehicle: 2012 Ram 1500
Rep:24
Exxzaust is on a distinguished road
Default Wheel Alignment? And will my tires stick out?
Im getting 285/70/17 kelly safari tsr tires and 17" 8.5 with 1mm offset, will these stick out anymore than stock? And should I go out and get a wheel alingment once there on? Thanks in advance
And that about TPM sensors? what do I do about these?
Dont be scared of the dark! Shine some light on it
Old 10-24-2012, 02:11 AM
Vehicle: N/A
Rep:1045
I don't think they'll stick out too far, but for sure they'll fill the fender out well.
Old 10-24-2012, 03:35 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
So if my research is accurate the stock 17x8.5" wheels have a 0 offset. So therefore your new wheels will stick out 1mm from where the stock wheels sit.... basically they will sit the same as stock. If you want them to stick out a bit go with a wider wheel, a lower offset wheel, or both.
TPMS should transfer over to the new wheels and an alignment is only required if you need an alignment currently.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 10-24-2012, 08:29 PM
Exxzaust's Avatar
Rep:24
what about if I go with 33" 12.5 wide? Will they stick out more? only downside i heard is the 12.5 wide are like big paddles in the winter
Old 10-24-2012, 09:07 PM
Vehicle: N/A
Rep:1045
i had 35/12.5s for a few winters and they were jus fine to me.
Old 10-25-2012, 02:52 AM
Exxzaust's Avatar
Rep:24
would I be able to fit 315/70/17 in there? I got a 2.5" leveling kit.
Im running fuel hostage 17x8.5 rims with 1mm offset
Old 10-25-2012, 03:36 AM
Vehicle: N/A
Rep:1045
I have a buddy (08 1500) here in south dakota that put the same size leveling kit on, and Cooper zeons, basically 33/12.5s on the stock 20s, and they had no issues.
Old 10-25-2012, 05:54 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
You should have went with a wider rim if you want to go that wide on the tire. JMO
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 10-25-2012, 08:14 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
i would have to agree when running a 12.5" tire between a 9"-10" wide wheel is recommended this prevents to much sidewall bubble, when running a 13.5" tire 10" to 12" wide wheels are recommended.
Old 10-25-2012, 05:40 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
i have 315/70 17's on 17X9 rims with 2mm offset, on my 11.everything clears perfect and no issues, its the same as a 35X12.5
2011 Hemi RCSB Sport 4x4
