Old 10-24-2012, 02:28 PM
Robizzle0191 Robizzle0191 is offline
Vehicle: 1999 Dodge Ram 2500 SLT Laremi
Trim Level: SLT Laremie
Robizzle0191 is on a distinguished road
Angry Nightmare Rebuild question.
Ok so the engine is running just fine not smoking and starts right up. However now I have this annoying Knocking in the motor. First I'm like great now the Rods knocking awesome but after thinking about it not to sure. Its not to loud at idle and it will knock like 2 or 3 times then it will be quiet for 3-4 seconds then repeat the same thing. But when I hit the gas it gets loud as hell and it does spead up but still stayes at a steady speed and theres probably a good second or so between knocks. Also there are no Metal shavings in my oil. Anyone got any ideas?
Old 10-24-2012, 02:36 PM
Resident Technician
Rep:1909
That could still be a rod. Other possibilities are a main bearing or wrist pin. Was this engine recently rebuilt and if so, what were the rod and main clearences?
Old 10-24-2012, 03:55 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I second RamTech on that.
Old 10-24-2012, 04:27 PM
The engine wasnt fully rebuilt the heads gaskets were replaced. The first time we started up the engine and some how it was still letting coolant into the engine so we had the heads shaved 6/1000 and then same thing however i then found that one of the intake manifold bolts wasnt tightened down in the back after tightening that down no more problems but come to think of it, it didnt start the knocking until the head was shaved do you think maybe the valve might be hitting the piston and maybe the valves need adjusted or something. the truck only ran maybe 10 minutes at the most when the head gaskets went out i saw smoke out of the tail pipe and immediatly got the truck home then ran it the 2 times when i noticed it was still smoking from the intake manifold and before the heads were shaved and before that there was no knocking or even ticking.
Old 10-24-2012, 04:38 PM
Resident Technician
Rep:1909
No, I don't believe you have a valve to piston clearance problem because shaving the heads a mere .006" isn't going to be enough to cause this unless too thin of a head gasket was used (assuming one is made that could cause this). You don't have anything adjustable in the valve train unless you converted it to a solid roller setup. I still believe you have a problem in the bottom end - most likely a rod bearing with main bearings and wrist pins running a respective 2nd and 3rd, IMO.
Old 10-24-2012, 04:48 PM
is there an easy way to check because I'm getting tired of tearing this thing apart seriously. And if it is that can the bearings be replaced from under the truck with the pan off and the motor still in the truck.
Old 10-24-2012, 07:57 PM
Resident Technician
Rep:1909
The oil pan has to come off and the caps need to be pulled in order to visually inspect the bearings. If the crank needs work then the engine will have to come out.
Old 10-24-2012, 08:21 PM
03cobrakid's Avatar
03cobrakid 03cobrakid is offline
Vehicle: 2012 Dodge Ram Crew Cab
Color: Saddle Brown Pearl
03cobrakid is on a distinguished road
check your flex plate. I have had them crack and sound like a rod knock.??
Old 10-25-2012, 03:54 PM
miaram miaram is offline
Vehicle: 2000 Dodge Ram
Trim Level: SLT Larmie
Color: Marone
miaram is on a distinguished road
Make sure your exhaust manifold is seated correctly and bolts are tight.
Old 10-29-2012, 02:36 PM
This might narrow it down I noticed and forgot to write it down sorry sometimes im retarded, but everytime it knocks the engine revs up not a lot maybe 100 rpm and it happens so fast it doesnt even register on the tach but you can hear it and you can feel the entire truck vibrate. One more symptom that might help narrow it down.
