More Overheating Problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-31-2012, 01:21 PM
DodgeRam360 DodgeRam360 is offline
Vehicle: 1998 Dodge Ram
DodgeRam360 is on a distinguished road
Default More Overheating Problems
so the past week my truck has not overheated until today i went to the store and it was fine and then on the way back if i went fast than 5 mph it would start to over heat and so i pulled over and went to put coolant into it and it was almost overflowing and ive changed the thermostat about a month ago and im not sure whats wrong with it now and the hose that goes from the radiator down to the engine is so hot it that i cant even grab it could that hose be clogged or should i just buy a new radiator to see if that helps or if theres anything else i could try first please let me know any advise would deffinatly help
Old 10-31-2012, 01:42 PM
Rep:1915
A clogged radiator is a possibility but so is a defective water pump or improperly installed thermostat.
Old 10-31-2012, 03:28 PM
but would the thermostat all of a sudden started acting up seeing as i changed it a while ago? and im almost positive i gotta change the water pump anyway becuz my trucks been going through coolant like almost a gallon a week. and ive never had a radiator get clogged before is there any way to check it or am i just gonna have to buy an other one?
Old 11-02-2012, 07:36 AM
Oldskoolram Oldskoolram is offline
Vehicle: 97 ram
Trim Level: RCSB sport
Oldskoolram is on a distinguished road
mine did the same thin g about 6 months ago i put in a new radiator and thermostat after the old thermostat seized and caused the engine to overheat which in turn caused the crappy plastic reseviors on the radiator to pop. so got a new griffin radiator new hoses and new thermostat, 2 weeks later got hot again, checked the flow it was fine but restricted,pulled the thermostat and left it out and poof no more running hot. As i live in houston this is not an issue because its hot hear most of the year. Not sure if this helps but hey it worked for me.
Old 11-02-2012, 07:48 AM
BrandonMski's Avatar
BrandonMski BrandonMski is offline
Vehicle: 2006 Dodge Ram 3500
Rep:24
BrandonMski is on a distinguished road
I'd suggest running without a thermostat. I've done it to two vehicles and they ran like a champ afterwards.
2000 Dodge Ram 1500 Sport 4x4 - 5" lift, 36" tires, CIA, exhaust, CB radio, bed liner, undercoated, and more
2006 Dodge Ram 3500 Laramie 4x4 - trans temp, EGT, boost gauges, 5" exhaust, CIA, Fass 95GPH
