Old 10-24-2012, 02:15 PM
HIstateRam HIstateRam is offline
Vehicle: 2012 Dodge Ram Outdoorsman
Trim Level: 1500 Outdoorsman
HIstateRam is on a distinguished road
Default Minimum wheel size
I have a 2012 dodge ram 2wd outdoorsman crew cab. I know the stock wheels are 17"............I was wondering if 16" or 16.5" wheels would fit? I wanted to put the pro comp rock crawler white wheels and I wanted it in a width of 12" but they only had it in 16" and 16.5" wheels. Can someone help me. Thanks
Old 10-24-2012, 03:45 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Yes you can go smaller, try and stay with integers though. For some reason when you get wheels that say have a diameter of 16.5 you can run into tire issues and most wheels diameters are integers, being 16 and 17 inches. But you can get smaller wheels, the only issue with tires that are a larger sidewall is they generally put a little more strain on the drivetrain but it's not like the vehicle cannot handle it. Big tires means larger inertia which means it takes longer to speed up and to slow down, they are also speed limited. But I don't see you doing 100+ MPH so no worries. Drag slicks are a different story, they have no thread and are very uniform. But anyways if you want big tires go for it.
Old 10-24-2012, 07:42 PM
Thanks for your help. So 16" or 16.5" wheels will fit over the brakes with no problem? That's true about the tire issues u said btw
Old 10-25-2012, 03:38 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Actually you can't go smaller than a 17" wheel unless you want to do some surgery on your brakes (not recommended).
I believe the older 2nd gen's and earlier can run a 16" wheel, but everything from 3rd gen up to current will need a minimum of 17" diameter to clear the calipers.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 10-25-2012, 04:41 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
on my aftermaket 17's i cant get my fingers between the caliper and rim
2011 Hemi RCSB Sport 4x4
Old 10-25-2012, 05:31 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
gotta grind if you want to go 16"
Old 10-25-2012, 05:33 PM
Color: Satin Orange
Rep:605
its a 4G...............
Old 10-25-2012, 09:20 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
17 is the absolute smallest you can go without murdering your break system, however as a basic rule of thumb you should try to run at least 18's if at all possible this allows for just a tad more clearance, i know on my 2012 ram i can't even get a 17 on there, there simply is not enough room. It honestly kind of makes me mad because i like the look of less wheel more tire much more than i do more wheel less tire if that makes any since lol.
Old 10-29-2012, 01:28 PM
ramvan2500's Avatar
Rep:128
You can go smaller but you will have to find a wheel that has a very deep wheel well. My ram van has 15's but the well is very deep. Other than wheels with a deep well, you could do what others have suggested and that is to grind down the caliper OR you could probably contact wilwood (my fav) and I'm sure they have a nice set of dual or even tripple piston calipers that can replace the stock ones that will also allow a smaller wheel. Personally, in terms of force I like smaller wheels because they put more force to the ground however in racing you have to be careful about your driveshaft critical speed, axle shaft critical speed, etc... Anyways, you could just use the 17's and still get larger tires, it's difficult finding them bulky tires for 17's that are cost friendly but anything is possible.
On my van when I put the new engine in, I am probably going to go with anything from 15-17 in diameter and 9" width for slicks. I have a low driveshaft critical speed (6200 RPM) so I have to get some very large tires in the rear so I don't throw the shaft. But I'm doing drag racing, you're going off road but eitherway it's still physics
Good luck
Old 10-29-2012, 01:34 PM
Color: Satin Orange
Rep:605
Either way its not going to be direct but i guess you gotta pay to play esp' when dealing with Dodge.
