Old 10-25-2012, 11:26 AM
DerPo's Avatar
DerPo DerPo is offline
Vehicle: 2012 Ram Express
Rep:35
DerPo is on a distinguished road
Default Upper Glove Box Mod...Write up?
Can anyone provide a link to a write up for adding the upper glove box? I ordered all the parts and they have arrived, I really dont want to break anything when I instal it.
Old 10-25-2012, 01:05 PM
davem2421 davem2421 is offline
Vehicle: 2012 Ram 1500
Trim Level: ST 4X2 1500 QUAD CAB
Rep:57
davem2421 will become famous soon enough
could you tell me where you ordered the parts from?
Thanks
Old 10-25-2012, 01:22 PM
DepsilonD DepsilonD is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express CA Edition
DepsilonD is on a distinguished road
I bought the upper glove box stuff for install on my 2012 Express from Mopar Online Parts. http://www.partswebsite.com/moparonlineparts/
As for installation, just do a google search of "ram upper glove box" and you will come up with some how to's from this forum as well as other Ram Forums. The install is not that hard, the most difficult part is getting the glove box door to line up. You will also need to get a few screws that are not supplied with the factor parts.
Old 10-25-2012, 01:27 PM
Grubrunner's Avatar
Rep:3883
http://www.ramforumz.com/showthread.php?t=113059
Grub out!
Old 10-25-2012, 07:22 PM
mcampbell mcampbell is offline
Vehicle: 2012 Dodge Ram Sport
Color: Mineral Gray
Rep:13
mcampbell is on a distinguished road
That's a good write up!
Old 10-25-2012, 10:56 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
I just did mine last week (my second conversion). The hardest part was getting the upper glove box door aligned and fastened to the dash. I used 4 #8 x 3/4" pan head sheet metal screws w/washers from Autozone to fasten it to the dash. Also don't forget to remove that little bolt that holds the original bin to the dash. When removing the original bin it will easily pop out if you pull on it from behind by sticking your hand through where the lower glovebox was located.
It will make more sense once you get started, it's maybe a 45 minute job but well worth the trouble to do it.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 10-26-2012, 12:26 PM
DerPo's Avatar
Rep:35
Got around to doing this, write up helped a lot. I had to go to the hardware store to get the screws. I have U connect, when I hit the phone button it says "U connect active, say a command" or something. But I couldnt find the USB plug, input?
Old 10-26-2012, 10:39 PM
jmr's Avatar
jmr jmr is offline
Rep:74
The USB cable is there to the left of the upper glove box wrapped in the main harness. If you turn on the radio the end of the cable will light up.
Old 10-27-2012, 07:38 AM
highwayman1's Avatar
highwayman1 highwayman1 is offline
Trim Level: Tradesman
highwayman1 is on a distinguished road
Is the USB cable in all models? And located the same spot?
Old 10-27-2012, 01:38 PM
jmr's Avatar
jmr jmr is offline
Rep:74
If you have the Uconnect option then check and see if the box has a USB cable in it like mine had.
This is what the end of the USB cale looks like, it has a light on the USB connection.
It was taped deep into the main harness behind the metal brace on the left.
The USB connection and Light Switch connector look like this.
