Old 10-25-2012, 03:35 PM
shane2012 shane2012 is offline
Vehicle: 2012 dodge ram 1500 sport 4x4
Trim Level: sport
Color: red
shane2012 is on a distinguished road
Default what tire size....again
i need help with tire size. I have a 2012 ram sport 4x4 and want to put 295/70/18's on.
will they fit without leveling or lifting?
if so what offset and backspacing?
any help would be appriciated i have gotten so many mixed responses and need more help. thanks!!!!!
Old 10-25-2012, 05:37 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
id opt for a leving kit, thats easily a 34" tire
2011 Hemi RCSB Sport 4x4
Vehicle: 2011 Ram
Rep:141
10mm or under on offset you will be fine
Old 10-25-2012, 09:39 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I would go for a 0 offset, my friend has that offset on.his ram and I.like the way it fits the truck better than my +12. A leveling kit always makes the truck.look better but I cleared my 285/60 and 305/55' on my 20's with no.problem except for the 305 rubbing the swaybar on hard turns.
Old 10-25-2012, 10:16 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
i would go with a +0 offset or a +6mm offset at most, and as said above you will want defiantly entertain the idea of putting on a level kit your stock tires should be very close to a 31 the tire you have listed is a bit bigger than that so you would want to at least level the truck to insure proper clearance there is no need to do a full lift just so the tire will fit if that is all you are after, might i recommend bilstein 5100 adjustable shocks set to 2.1 or 2.8 that should do the trick and level you out a bit you could also get a set of pro-comp zx-20014's and set them to 2.75 that would do it also.
i can get you a set of bilstein's for $230 with free shipping anywhere in the lower states
procomp zx-20014's would be $215 with free shipping also. if interested my contact info is below.
Thanks
Jeremiah Hinkle
Lathrop, mo
855-432-3278 toll free
816-686-2176 personal number(i can answer simple questions via text on this number for all orders please call our toll free number above.)
jhinkle@discountautoperformance.com personal email
Old 10-26-2012, 12:17 PM
Trim Level: sport
Color: red
yes, all i am after is to be able to have the 295/70/18's fit without doing a leveling kit. My stock tires are 33".
Old 10-27-2012, 05:40 PM
Trim Level: sport
Color: red
what backspacing would you recomend of i go with the 0 offset?
Old 10-27-2012, 10:24 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
the offset and the backspacing are similar however if you go with a 20x9 and a 0 offset your backspace would be 5" i dont remember the exact formula to come up with this i will try and find it in my notes after a while and post it up for you.
i did find a nice chart though i will attach it for you
Old 10-28-2012, 10:32 AM
Trim Level: sport
Color: red
thanks for your help!!
Old 10-28-2012, 12:50 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Your Welcom
filler
