dodge ram 1500 questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-25-2012, 10:17 PM
adampatrick adampatrick is offline
Vehicle: 1996 dodge ram 1500
Trim Level: laramie
Color: grey and red
adampatrick is on a distinguished road
Default dodge ram 1500 questions
I have a 1996 dodge ram 1500 wondering how high i need to lift it so i can fit 35s on?
and what is the cheapest route for this lift?
also wondering i have a great deal on 2004 dodge ram chrome rims with 35s on them will those rims fit on the truck?
will i need some preformance upgrades for my truck with these bigger tires?
Old 10-25-2012, 11:54 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Sure...
Lift wise, there's really not a cheap route. You want a decent riding suspension that doesn't destroy your handling or cause other components to wear too quickly.
For lower end stuff, rough country makes about the least expensive and complete package. A 5inch setup should have new front coils, a rear add a leaf (not blocks), longer front control arms to recenter your axle and something to work with recentering the track bar, although I can tell you from experience you'll want to replace it with a better design.
On the other end, a company called Dodge Off road makes higher end stuff that is designed to take the worst punishment of honest off roading.
Later rims will fit your truck but they are designed for 9/16 lugs, not the 1/2 inch ones your truck comes with. You can't convert, and though a lot of guys run thier original lugs with the newer rims I find that a bit unnerving.
Lastly, as performance mods..yes you'll need one. And its a biggie. 4:56 gears. Oh you can waste a alot of money on bolt on motor mods and the like, but until you gear down, you'll not only be down on power, but your mileage will be in the gutter.
I'd install the suspension, run 33's and put up with the marginal performance loss. Next install the gears, then tires.
