Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-26-2012, 12:45 AM
arkansas arkansas is offline
Vehicle: 1995 D150
Trim Level: Royal SE
Color: Maroon
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
arkansas is on a distinguished road
Default Tuning and Carb Adjustments
I just typed about 1,000 words describing the background. During the typing, I took a phone call and when I came back this forum had logged me out and I lost my post. I do not have the heart to do that again. I'm sorry.
I have a 1985 D150 Royal SE with a 318 and a Holley 2bbl 2280.
I have rebuilt the carb and it runs now except it dies after driving when I stop at a stop sign/light or slow down to turn in. It will immediately restart, but I think the idle is too low while in gear. It idles very well and revs well while in park. While cold, before the choke opens, it does not die while stopped in gear.
I think I need to tune the carb and maybe adjust the timing, but I cannot find a good source to do that.
Can someone please provide me with a good set of instructions for tuning/timing this engine and carb?
Old 10-26-2012, 02:19 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Your float level may be set too low.
Old 10-26-2012, 02:42 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I'm not sure of the exact year they did it, but I'm thinking it was actually in the late 70's when they made it impossible to adjust those carbs in any way as to tuning. About all you can do is make one change to the accel pump linkage and adjust the idle with the idle adjust screws in the linkage. It's been a while, but I think they had two idle set screws, one for cold running when the choke is involved, and one for warm operation. Sounds like you need to crack open the warm operation screw a bit.
Old 10-26-2012, 06:48 PM
Vehicle: 1995 D150
Color: Maroon
I do have those adjustments that you mentioned, but I also have two mixture screws on the front of the carb. This carb may be older than the truck or maybe on 85s you could still adjust.
Old 10-26-2012, 06:49 PM
Vehicle: 1995 D150
Color: Maroon
How would that cause this symptom? I am not being smart, I am just asking to learn.
Old 10-27-2012, 01:25 PM
Rep:85
You definitely can't adjust the 80's era carbs, so I'd bet it's an early 70's model. Ok, so I'd gently tighten (actually don't tighten, just flush them down) the screws all the way down, then open about 2 full turns. That's a good place to start. You can tweak a quarter turn more or less at a time, 2-2 1/2 turns is going to yield the best idle quality. If you're quick you can do this with the engine running and gauge run quality (bump up the idle screw to give you around 2000 rpm. Wherever the engine runs best is pretty much where you want to set it. If you get no obvious change, you probably have a clogged or damaged idle circuit. Usually, when it's toast, you can adjust one screw and hear changes while adjusting the other does nothing. Then set your idle screws and try it on the road.
Old 10-31-2012, 11:34 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
will this ajustment work for a truck that runs rough and has a bit of a miss at cold idle. it sounds like he has the same carb i do in my 82. its hard to start when its cold and runs rough till its warmed up a few min. but then it purrs like a kitten no issues on re start.
Old 11-01-2012, 01:07 AM
Rep:85
Well it won't hurt. Sounds more like a choke issue.
Old 07-18-2015, 10:22 AM
JcatD150 JcatD150 is offline
Vehicle: 1985 Dodge Ram D150
Color: Blue
JcatD150 is on a distinguished road
Hello , I have an 85 D150 and had issues like this, I'm actually still working out the fine tuning because I'm getting a slight hesitation.
The carb I had on there had it's mixture screws blocked or plugged but I eventually bought a new/rebuilt Holley 2 barrel which has mixture screws I can turn.
If you're facing your engine, the mixture screw to your right is the idle, and the one to your left is the air mixture. Shut off your engine and close both screws very gently. Once you feel them stop open them both 11/2 turns and then start your engine and see how it runs, then you can adjust from there.
There are also screws on the back of your carburetor which controls the idle by propping the accelerator back which would be like the same thing as pressing your accelerator down, you may have to adjust that screw to prevent stalling.
You may also want to check all vacuum lines, fuel filter, fuel pump, fuel lines ( I replaced all of mine) and make sure your choke works properly. It should Idol hi from a cold start and then you kick it down and it will run at a low nice idle.
1985, 318, carburetor, timing, tuning
