Old 10-27-2012, 04:17 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
What's the power diff between having a 6.4 cam to a comps
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 10-27-2012, 09:40 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
how many guys are actually running the 6.4 cam? 1 or 2?
For the labor and tuning involved, I'd hold out and wait for a good aftermarket cam. If it were a DIY install, I could see how the low price would be attractive.
07 rclb cummins. Efi live by silver bullet tuning
Old 10-28-2012, 01:21 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
It is a DIY install if you have the right tools. I have helped on two installs....not as bad as you would think...but it is bad if you get it one tooth off! There is an 11 running a 6.4 cam with a 300 dollar spring kit with no tuning just to show it is possible. No codes on the 6.4 cam.
I am going to do the same thing here in a month or so, and also swap to a ported 6.1 manifold. Then comes the nitrous plate
Old 10-28-2012, 01:51 AM
jlibert's Avatar
Trim Level: express
great info, thanks.
Are there any before/after dyno results?
What are the sotp results?
thanks,
jp
Old 10-28-2012, 10:35 AM
916Timmy's Avatar
Rep:1443
My buddy did the 6.4 cam and PWR heads on his 09 Chally 5.7 and it picked up a ton! The heads are a big part of it, but the cam is almost .100 more lift than the stocker!
I just don't see the point in spending 800 bucks on a cam when a 60 dollar stocker has pretty close to the same specs! I'm piling up all the stuff I need for my truck, and as soon as it is completed and tuned...it will be here!
The 6.4 cam is in the .56x range compared to the .61x range of Comp. BUT...the 6.4 cam is good without the phase limiter that comp makes!
Old 10-28-2012, 01:12 PM
jlibert's Avatar
Trim Level: express
^^For the lope man!! ha.
Points well taken. I like the fact that the 6.4 cam is a factory part (I've seen aftermarket cams die a quick death). Another benefit to the 6.4 cam is that it should pass emissions testings without any hassle. What are your impressions on HHP advertising that the cam phaser limiter alone could add 20-30 hp? I'd guess that the factory cam phaser isn't solely in place to add power -- it probably has some emissions-minded function as well.
Old 10-28-2012, 02:20 PM
916Timmy's Avatar
Rep:1443
I don't see how limiting the VCT system could add horsepower....VCT is used to add low end and high end power by advancing and retarding cam timing.
Old 10-28-2012, 11:02 PM
jlibert's Avatar
Trim Level: express
unless it's like I'm saying. They're pulling more than necessary on top to limit cylinder pressure and NOx.
