Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-27-2012, 04:49 AM
TheSuperDelxue TheSuperDelxue is offline
Vehicle: 2009 Ram 1500
Color: Dark Slate Gray
TheSuperDelxue is on a distinguished road
Default Passenger side heater doesn't work and a loud clicking noise coming from the dash
I have a 2009 Dodge ram with dual climate control and just today I noticed a loud clicking noise coming from the dash. It sounds like its coming from behind the upper glove box. I also noticed the passenger side is suck on air conditioning while on the drivers side everything works perfect. I did some research and it sounds like one of my actuators is bad but when I took my dash apart and pulled out the two located below the radio they were fine. I also checked the one behind the lower glove box and that one was fine as well. Any ideas on what it could be?
Thanks,
Kevin
Old 10-27-2012, 08:45 AM
Rep:1885
How did you check them?
Old 10-27-2012, 03:36 PM
I took apart the three actuators and didnt find any stripped gears so I assume they're fine.
Old 10-27-2012, 04:04 PM
Rep:1885
The actuators may still be bad. Did you check the operation of the doors themselves?
Old 10-28-2012, 09:45 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
there is recall for the actuator motors. recall K17 i think. the dealer will replace the know problematic motors and re-flash the controller. i had the same problem, i replaced the motors my self prior to knowing about the recall, just got my refund check in the mail from chrysler yesterday.
