View Poll Results: which transmission for the R/T?
6 speed 21 30.88%
8 speed 38 55.88%
forget about it and get an 09-12 9 13.24%
Voters: 68. You may not vote on this poll
Old 10-27-2012, 09:21 AM
eggwhite93 eggwhite93 is offline
Vehicle: 2011 Ram 1500 CC
eggwhite93 is on a distinguished road
Default 2013 R/T question
I am thinking about picking up a 2013 R/T and I have one question for the masses.
I was looking at the 2013 order guide that is in this post:
http://www.ramforumz.com/showthread.php?t=123635
As far as I can tell, at first they will come with the 5.7 and a 6 speed and 4:10 gears, but will eventully (late availability) come with the 8 speed and 3:92 gears.
The question is, should I get one with the 6 speed or wait for the 8 speed?
2011 RAM 1500 CC Sport 4X4
2007 Jeep Wrangler Rubicon
Old 10-27-2012, 09:25 AM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
i don't think anyone will really know until we see how the 8 speed trans holds up. Sure an 8 speed trans sounds good for gas milage but it sure would be shifting quite a bit when driving inner city.
Mods: Lowered and Blown.
Old 10-27-2012, 09:32 AM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Personally I would wait until the 8 speed rolls out. If you want to get an idea of how the 8 speed handles being tested, go test drive a charger or 300 with the 3.6 pentastar that has the 8 speed transmission.
The ratios that will be in this transmission will make the truck faster off the line while getting better MPG's.
http://www.allpar.com/model/ram/dodg...owertrain.html
Chrome... in moderation.
Old 10-27-2012, 10:04 AM
This truck will be more of a toy than anything so gas milage will not be a desciding factor.
This is why I am leaning twards waiting.
Old 10-27-2012, 11:21 AM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
Correct me if I'm wrong. But I believe the new 8 speeds two first gears are for towing purposes which mean better launching and getting up to 60 quicker. That's how they can get a new charger with the v6 to 60 in 6 secs. And you have to think that car is only 300 pounds lighter than a reg cab express. So I'm sure the 2013 rt will be a whole lot faster than a 2012
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 10-27-2012, 09:43 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
I'd go with the 6 speed (really 5) if you're going for performance. Assuming the case size is the same dimensions, there will likely be less room to to add more clutches with the 8 speed. That is just a total guess, as I don't know what the specs are on the 8 speed.
07 rclb cummins. Efi live by silver bullet tuning
Old 10-28-2012, 12:03 AM
2010drive 2010drive is offline
Vehicle: 2012 Ram 3500 SRW Limited
2010drive is on a distinguished road
You have it the other way around...the 5 speed from 09-11 was really a 6 speed.
Old 10-28-2012, 03:44 AM
Rep:2620
2009 & 2010 i believe had the 545RFE transmission, it was a 5 speed
2011 & 2012 had the 65RFE transmission, it was a 6 speed
both had the same outer housing
the R/T had a different torque converter, than the rest of the models & i believe it had a 4:10 ratio rear differential
Click on the image of the Rams at the top of the page
scroll down to the NEWS, i think it is the 2nd line down
i posted what i could find out about the 2013 models
2013 ORDER GUIDE, posted by Horseman
http://www.ramforumz.com/showthread.php?p=909208
Old 10-28-2012, 02:29 PM
jlibert's Avatar
Trim Level: express
?? read my post again. Mechanically it's a 5 speed.
In other words, more gears could potentially equal less room to add friction material. Such is the case with the older 48re vs the newer 68's for the diesel crowd.
Old 10-28-2012, 03:24 PM
Talking
2009-2012 are the exact same transmission. All they did was retune it for 2012 and rename it. It's a 5 speed with a split gear so essentially it's been a 6 speed since 2009
