2013 R/T question - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram R/T
View Poll Results: which transmission for the R/T?
6 speed 21 30.88%
8 speed 38 55.88%
forget about it and get an 09-12 9 13.24%
Voters: 68. You may not vote on this poll
Old 10-28-2012, 02:48 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Edited...correct info below.
Old 10-28-2012, 03:20 PM
2010drive 2010drive is offline
Vehicle: 2012 Ram 3500 SRW Limited
2010drive is on a distinguished road
http://www.allpar.com/mopar/transmissions/545RFE.html
Old 10-28-2012, 10:14 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
Originally Posted by 2010drive View Post
2009-2012 are the exact same transmission. All they did was retune it for 2012 and rename it. It's a 5 speed with a split gear so essentially it's been a 6 speed since 2009
Originally Posted by jlibert View Post
I'd go with the 6 speed (really 5) if you're going for performance. Assuming the case size is the same dimensions, there will likely be less room to to add more clutches with the 8 speed. That is just a total guess, as I don't know what the specs are on the 8 speed.
That's what I've said all along.
anyway man, call it what you want. 5 speed, 6 speed, whatever. It's the one you'll probably want.
07 rclb cummins. Efi live by silver bullet tuning
Old 10-29-2012, 10:40 AM
ck319 ck319 is offline
Vehicle: 2013 Ram
ck319 is on a distinguished road
I'm waiting for the 8-speed. Should be better performance and fuel economy.
Our rep told me to expect them around February or March.
Old 10-31-2012, 07:40 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
This will blow all your minds....the 545RFE and 65RFE are actually both 45RFE's which was the 4 speed trans. All chrysler does is change the pcm program and BOOM new gears magically appear. The 545RFE name actually means a 4 speed, 5 torque rating, rear mounted, fully electronic trans with 5 forward gears pretty confusing. The 65RFE is just another computer program. If you take apart a 45RFE and a 65RFE the only difference is the valve body and trans pan.
Also since I've already gotten to take apart an 8 speed trans I can say they are pretty stout. There is only one part about them I don't like, there is an aluminum drum on the out side of the gear train that transfers all the torque coming into the trans to a rear gear set. It brought back memories of the old chevy 700r4 sun shell. But since the company (ZF) that makes the 8 speed has been using it for more than ten years in European cars they've already been tested. The 8 speed will change the game for chrysler, Its an awesome trans, and it doesn't eat up 60-70 hp like the 65RFE does.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 11-25-2012, 10:50 AM
DiverDanRamMan's Avatar
DiverDanRamMan DiverDanRamMan is offline
Trim Level: R/T
DiverDanRamMan is on a distinguished road
Will we ever get a tuner for the 2012 if they change to 8 speed trans in 2013?
Old 11-25-2012, 05:36 PM
bighemi04's Avatar
Vehicle: 2017 1500 Laramie
Rep:623
An 8 speed would be awesome. I had to pull the trigger when I had the wife at the dealer or I may have waited for it
Old 12-28-2012, 05:13 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
I didn't think they was putting a 8speed in the R/T. and even if they did it would have that crazy nob-shifter.
SPONSORED BY
BULLY'S PERFORMANCE
Old 12-31-2012, 01:10 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
ya f that stupid knob shifter lol go race with that
Old 12-31-2012, 11:01 PM
silver12vcummins silver12vcummins is offline
Vehicle: 2012
Trim Level: outdoorsman
Color: true blue pearl
silver12vcummins is on a distinguished road
am I the only one that likes the knob shifter..?
