1998 Ram 1500 DIY CAI!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 10-28-2012, 07:04 PM
ourtang ourtang is offline
Vehicle: 1998 Dodge Ram 1500 4X4
ourtang is on a distinguished road
Default 1998 Ram 1500 DIY CAI!!!!!
So, I'm new here and been reading alot of post for the 1500. So far I have done the TB mod and today finally put on my Durango air scoop and made it into a CAI. Next I will have the stock ECU flashed and go from there. I must say that the Durango setup looks alot nicer and cleaner and not so full under the hood. VERY NICE SITE with alot of useful info!!!
Old 11-01-2012, 10:25 AM
Canadian19981500 Canadian19981500 is offline
Vehicle: 1998 1500
Trim Level: Base
Color: red/grey
Canadian19981500 is on a distinguished road
Do you have a picture?
This is what i did and the throttle response change was noticeable.
Old 11-01-2012, 06:15 PM
I did the same thing except I used the air intake tube from the Durango and ran it from the round intake and then put the filter on the end of the tube, but I turned the tube toward the front of the truck to the side of the grill. I like your setup though. There shouldn't be any turbulencve in the air going into the TB the way you did yours. NICE!!!!
Old 11-01-2012, 07:38 PM
Vehicle: 1998 1500
Trim Level: Base
Color: red/grey
It was a pain to get it in there... there was a good reason the factory did it different on the truck.
I had the stock air breather set-up with a K&N filter but did feel any difference. The change to this most changed throttle response. I figured with winter coming here it wouldn't mind sucking up some warmer air.
In the summer i would like to run a tube to the front. But... with more air, you need more fuel.
Right now I average about 17 mpg with the 5.2. Before I changed the cat I was only getting 14 mpg. The cat clogged and after the replacement the truck woke up.
