Old 12-06-2012, 02:15 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
wow nice!! which Miller tool? and where did you tap in?
I don't know the number, but if you search line pressure tool, you will find it. You bolt it in the trans case where the pressure sensor goes and then the sensor is bolted into the tool.
Old 12-06-2012, 02:33 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
that's really hot..cooler workin? pump?
Old 12-06-2012, 06:33 PM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
Wow that's insane!!!
Old 12-06-2012, 06:41 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Originally Posted by 2010SCRam View Post
Been driving it easy and got it up to 170. Just got back from the dealership and the Service manager and I took it for a short wild ride and got it up to 200. Felt like it was slipping and chugging to me but he said it felt like the motor was breaking up and missfiring cause when it did shift it was firm. I drove it moderate on the 6 miles home and it continued to hover around 200. Been sitting in driveway in N idling for past 10-15 minutes with AC off and it hit 211 and has been bouncing between 210 and 211 for a couple minutes. It's 78 degrees and my hoods open.
If you sit and idle,the fluid will not circulate,and it will keep going up in temp,it has nothing to do with the tranny,or amnything else.
Dont sit and idle,anybody can use there evic and see that I am right.
I found out the hard way,so dont sit and idle.
200 while driving is way to high.
You can buy a fan Flexalight that will sit on your tranny/oil cooler and come on at whatever temp you want.
You have to keep the temps in the 160-1180 range,even towing 5 tons I never see 200 degrees.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 12-06-2012, 06:45 PM
Color: Mineral Gray
Rep:72
You need someone else to drive your truck and let us know what he thinks.
I though Edge converters were only good up to 450 HP???.
I hope you have a 11 inch converter,cause there 9 inch will not work in our trucks from what I have read.
Best of luck,but something is still not right with those temps.
3:92 gears.
