What size radio will fit? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 10-29-2012, 10:15 AM
countryboyco99's Avatar
countryboyco99 countryboyco99 is offline
Vehicle: 2010 Dodge Ram 1500 Quad cab
countryboyco99 is on a distinguished road
Default What size radio will fit?
I have a 2010 RAM 1500 QC SLT with the basic res cd/mp3 radio and want to change it out. Will a double din fit with out any mods to the dash or am i better off looking for a single din radio. Also is it worth it to look for a upgraded stock radio with gps and dvd? Thank you for any help.
Old 10-29-2012, 11:31 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Hi. Welcome to the Forumz! Pretty sure the radio size is double din. And you wouldn't have to do any mods to the dash , if anything they might make a bezel to accommodate the size if whatever radio you were buying was a bit smaller.
I have the 730N with the navigation and dvd, and I really like it. The navigation is nice to have, and for you being in the states it has the traffic updates and gas prices being able to look up and that type of stuff.
I think I have used the dvd player part of it once.
Hope this info helps, and once again Welcome!
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 10-29-2012, 11:50 AM
Thanks for the info. What would I have to go through to upgrade to a stock DVD/nav radio and how much would it cost or would it be cheaper to just go after market?
Old 10-29-2012, 12:21 PM
glitzbd glitzbd is offline
Vehicle: 2014 RAM 1500
glitzbd is on a distinguished road
I think it will end up being cheaper going aftermarket. OEM radios are expensive unless you find them used, and if you have the 130RES w/o UConnect (no phone buttons) you'll need to add UConnect for full function.
Also to fit a Double-DIN there is some modification, and it involves cutting a metal support to ensure proper fit. But overall you'll probably end up with the feature set you'd get out of a more expensive OEM unit, and end up spending less! I am currently looking at the AVH-P4400BH from Pioneer as it looks like a nice fit for my truck!
Old 10-29-2012, 03:18 PM
Rep:2968
The stock radios for 2009 - 2012
are 1.5 DIN
DIN is the height & width measurement, it does Not consider depth
The third most popular car stereo size is what is called “1.5 DIN” or “DIN and a Half” which measures approximately 3 3/16″ in height and 7 1/8″ in width. Car stereo depth size for 1.5 DIN radios varies between vehicle manufacturers and models but most vehicles with a 1.5 DIN radio tend to have a very shallow depth that only measures around 7″. This type of car radio is usually found in American vehicles like Chevrolet, Cadillac, Dodge, GMC, Plymouth, Pontiac, etc. A 1.5 DIN sized opening can accept a 1.5 DIN car stereo or a single DIN car stereo using an aftermarket dash kit.
2 websites, CRUTCHFIELD, or INSTALLER have suggested radios & install help
a 2 DIN radio just takes a bit of metal trimming to install & usually need a different bezel
the 4th generation RAMs are easy to remove, only 6 screws, IF you don't have the full floor console, if you have the full floor console, it is a little more involved
if you have a 115V outlet
radio
