Old 10-29-2012, 04:14 PM
dean98ram1500 dean98ram1500 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Laramie SLT
dean98ram1500 is on a distinguished road
Default Camshaft upgrade
I'm looking to put a camshaft in my 1998 5.2l v8 and i was looking at a hydraulic roller with around a .500 give or take on intake/exhaust and around a 265 duration. With these specifications should I need to replace anything else like valve springs and what not? Thanks.
Old 10-29-2012, 04:21 PM
Rep:1909
Yeah, replacing the springs will need to happen. Check the pushrod length as well; you may need to change those, too.
Old 11-01-2012, 12:17 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Definitely change springs, the stockers will never hold up. Definitely upgrade the pushrods. Stock length should be okay, but you definitely want stronger ones. The added lift vs heavier spring loads will induce flex in the stockers. That's the last thing you need as the rpm's rise. I'd also add hardened valve spring retainer locks. It's cheap insurance. Also, expect to need computer mods. Sounds like CompCams Xtreme Energy XR265.
http://www.compcams.com/Company/CC/c...?csid=661&sb=2
5.2 liter, camshaft
