Old 10-29-2012, 06:30 PM
offrdramz00 offrdramz00 is offline
Vehicle: 2000 ram 1500 4x4 off road
Trim Level: off road edition
Color: red
Rep:19
offrdramz00 is on a distinguished road
Default starter problems??
i have a 00 ram 1500 5.9 4x4 off road package, im recently having problems when trying to start my truck, it turns over then stops the starter makes no noise so i turn the truck off then try and start again and it fires right up, is the starter sticking after a few turns? any advice would be great, i have a new battery about two months old 810cca no problems with that had it testes, im assuming the starter is on its last leg, though it doesnt do this all the time just the past two days....
Old 10-29-2012, 06:52 PM
Rep:1885
Take a volt meter and check voltages at both starter wires with the key in the start position. If the voltages are ok, check for a voltage drop across the ground. If that's ok, you have a starter problem.
