Old 10-30-2012, 12:23 AM
Havoc5454 Havoc5454 is offline
Vehicle: 2012 Dodge Ram 1500
Havoc5454 is on a distinguished road
Default New to the forum/and questions
Been lurking for a while reading up on everything. Finally purchased my own truck today. It's a black 2012 Ram 1500 4X4. Got a lot of appearence items ordered but I mainly had questions about the suspension part of it.
Here is what I have been planning to do.
-Rough Country 6 in. suspension lift
-Moto Metal 962 - 20X9, 5X5.5, O.S.-0MM, BS-5.00 in.
-Nitto Trail Grappler 37 inch, 12.50 wide
Will this fit with the 6 inch lift? I have been reading on the forums where some people use the Bilsteins shocks up front with a spacer in the back. If I do need to use those where can I buy them at? and also will I need any sort of wheel spacer with those wheels?
Old 10-30-2012, 12:25 AM
This will fit perfect and exactly what you listed is on my truck
The Bilsteins and rear coil spacer isn't necessary, unless you want to really level out the front. Which you set it at 1.4"
But if you want to maximize use of the Bilsteins, you need to set it to either 2.1 or 2.75, you'll need a 1"-1.5" rear coil spacer or even a 1.75". This can be purchased from top gun customz.
This will keep you level or with a slight rake of less than an inch
Old 10-30-2012, 12:26 AM
Oh, and Welcome to the Z and congrats on your new purchase
Old 10-30-2012, 12:29 AM
Thanks! Your truck looks beautiful. Are you using the Bilstein shocks and spacer or just the lift by itself?
Old 10-30-2012, 12:31 AM
Yes sir and thanks!
In my pic below, Bilsteins are set to 2.1" and I have a 1" rear coil spacer and have a 1/2" rake
Old 10-30-2012, 12:37 AM
Yes sir and thanks!
Okay awesome. last questions,
-I guess the Bilsteins just replace the shocks that come in the RCX kit?
-and where can I buy the Bilsteins and the spacer at?
Old 10-30-2012, 12:43 AM
Bilsteins replace your front factory shocks as the lift kit uses your front stock shocks.
If you google Bilsteins 5100, you'll find quite a few online retailers that sell them.
Or I can price you out a set if you'd like
Rear coil spacer can be purchased from top gun customz
Old 10-30-2012, 01:07 AM
So will I still use the strut spacer with the different shocks? What price can you get the shocks at? and what total amount of lift will all this achieve?
-sorry for all the questions.
Just trying to get it smoothed out before I go to the shop tomorrow.
Old 10-30-2012, 10:33 AM
Are you already at the shop ordering all the stuff?
But to answer your question...you will still use the strut spacer.
That is how you get the lift. The Bilsteins will level out your truck...
Our trucks come with an avg rake of 3" and the lift kit only eliminates 1" of that
Old 10-30-2012, 11:21 AM
I'm going by the shop today to see about labor pricing. Ill probably buy the lift through them because they offer a warranty on it installed. Then see if they could throw the shocks and coil spacer on with it.
Should I run any kind of wheel spacer with these rims and tires?
