Old 10-30-2012, 11:28 AM
Originally Posted by Havoc5454 View Post
I'm going by the shop today to see about labor pricing. Ill probably buy the lift through them because they offer a warranty on it installed. Then see if they could throw the shocks and coil spacer on with it.
Should I run any kind of wheel spacer with these rims and tires?
You will not require spacers for those wheels.
They will clear everything
If the shop tells you otherwise, they dont know what they are talking about
In all seriousness, it will fit even if they tell you it wont.
Old 10-30-2012, 01:40 PM
Havoc5454 Havoc5454 is offline
Vehicle: 2012 Dodge Ram 1500
Havoc5454 is on a distinguished road
Haha alright awesome. Thank you for all the help!
Old 10-30-2012, 03:46 PM
Alright so the shop wont do the shocks and coil spacers. And they wont do any rough country products. So I guess my next question is will those wheels and tires fit with the pro comp 6in. Lift by itself?
Old 10-30-2012, 06:13 PM
Why wont they do rough country products?
Why wont they install the shocks and coil spacer?
Why are they pushed Pro Comp?
I personally think you need to find another shop to install this.....
Just my 2 cents
Old 10-30-2012, 10:57 PM
Just my 2 cents
Rough country just isn't one of the companies they use because they do not meet their warranty standard. Pro Comp was just my second choice. And they won't do the shocks and spacer because all the work they do get's a lifetime warranty so if the shocks and spacer were to cause any problems with the truck it would fall back on them and not be under a warranty.
Old 10-31-2012, 12:16 AM
Is this a dealer or a shop?
Sounds like a dealer as every dealer seems to push Pro Comp or the Mopar lift
Mine did too and I told them I didn't want to and got Rough Country and Bilsteins installed and still got my warranty covered.
Either way, Pro Comp is a good kit.
Do you need to purchase this kit from them or can you purchase elsewhere?
Old 10-31-2012, 12:30 AM
They are both a dealer and an installer.
Were you able to keep the factory warranty with your lift and everything? This is something very important I need to find out. Don't want to void that.
And I can buy the lift elsewhere but if you buy through them you get a lifetime warranty and if anything breaks they will fix it for free. Although If i can find the lift for pretty cheap somewhere I'd rather do that. I believe he said they charge $540 to install a lift kit. They quoted me 2450 for the 6 inch pro comp installed.
I've got my wheels and tires ordered. Although I went with different wheels. Same tires.
Old 10-31-2012, 12:36 AM
Yes sir!
Dealer was hesitant at first.
I then told em screw it and ill go elsewhere.
Why should I pay for something I don't want.
They looked into it, purchased the lift kit for me. I purchased the Bilsteins and rear coil spacer and they honored the warranty of everything
All suspension related
$540 is good price for labor. Actually really good
Old 10-31-2012, 12:45 AM
Yes sir!
Do you think the 37X12.5 tires will fit with just the Pro Comp 6 inch lift? If that's the case I'll just do that without the bilsteins or spacer.
Old 10-31-2012, 10:12 AM
If you are still going with the 0 offset 20x9 wheels, it will and should
