Just Ordered Haloween Special - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 12-03-2012, 10:46 PM
1500driver 1500driver is offline
Vehicle: 2012 Ram 1500
1500driver is on a distinguished road
Can you post pics of the interior install? I'm planning to do this install soon on my new 2012, and would really prefer a clean flush mount setup. Would like to see how your turned out!
If you have any tips in regards to the install that would be great too, but I expect it to be pretty straight forward....
Thanks!
Old 12-03-2012, 10:56 PM
Anyone know of some other options for interior? I'm going to order the compressor kit with my bags, but was hoping to find another gauge/activator switch. Something like the airlift pedastal mount. The airlift gauge is available in a pedestal mount, with the inflate/deflate controls integrated in the dial. Ideally I would like to find something similar, in a flush mount.... and with a 0 - 60 PSI guage as offered by TLC. Unfortunately, other systems require much more PSI, so the common gauges are all 0-200, which makes it hard to read an accurate PSI at lower levels.
I'd prefer a flush mount system, but would be ok with a decent pedestal mount that looked good if I could find it in a PSI range that would work....and was a clean looking install.
The gauge I'm referring to can be seen here.... http://www.autoanything.com/suspensi...A5862A0A0.aspx
*EDIT*
Which after looking at, I realize is actually a 0 -100 PSI gauge, which is a whole lot better than a 200 PSI guauge. Not as preferable as a 60, but I could live with that.
Anyone tried this setup??
Old 12-03-2012, 11:19 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default TLC Install Options
1500D,
You could go wireless with the WirelessOne compressor and remote. Links on our website for that. Costs about $220-240 after AirLift $50 rebate currently on.
Here are 3 installs of our wired Viair compressor done by Josh aka ArmyofOne, our Z rep and 2 Z members. As you'll see, the last 2 deconstructed our panel and custom-installed the switches and gauges - very trick!. Thx LCHauler and RickaBev.
http://www.ramforumz.com/showthread....089#post852089
http://www.RamForumZ.com/showthread.php?t=112849
http://www.RamForumZ.com/showthread.php?t=115270
Please let us know if you have any questions.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 12-04-2012, 11:57 AM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
Default Gauge
Sorry it took so long to get the interior pics up here they are. My gauge and my light solution form Princess Auto for a nice and cheep 4.99
