Old 10-30-2012, 02:51 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
Default Pinouts for uconnect/auto dim mirror?
Anyone know the pinouts for the uconnect mirror with auto dim? part number
55157457AB, 55157457AC??
Mainly want to know what wires go to the power and negative for the auto dim, and what wires go to the plug in the back of the 730N.
Old 10-30-2012, 05:32 PM
Rep:1884
Pin Circuit Wire Color Gauge/Size Function
A1 X712 DG/LB 22 MICROPHONE 1 IN (+)
A2 X792 DB 22 MICROPHONE IN (-)
A3 X722 LB/DG 22 MICROPHONE 2 IN (+)
A4 NO CONNECTION
A5 NO CONNECTION
A6 NO CONNECTION
A7 NO CONNECTION
A8 Z911 BK/LG 18 GROUND
A9 L1 WT/RD 18 BACKUP LAMP FEED
A10 X835 OR/GY 22 SENSOR GROUND
A11 NO CONNECTION
A12 NO CONNECTION
A13 F943 PK/LG 18 FUSED IGNITION RUN-START CONTROL OUTPUT
A14 P112 TN/OR 22 AUTO DAY/NIGHT MIRROR (+)
A15 X793 DG/YL 22 MICROPHONE FEED
A16 P114 TN/WT 22 AUTO DAY/NIGHT MIRROR (-)
Old 10-30-2012, 05:36 PM
Rep:126
Funky Butt Lovin'! I didn't expect the results so quick. :-) Mucho Gracias RamTech!
Old 10-30-2012, 05:38 PM
Rep:1884
You just caught me at the right time.
Old 10-30-2012, 05:42 PM
Rep:126
So, to power the auto dim, I took up the A14 to + and A16 to - for the mircophone I hook up A1 + and A2 -? There are two microphones on the mirror?
Old 10-30-2012, 08:54 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
Yup, 2 microphones in the mirror.. You can see them on the top of the mirror
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 11-07-2012, 12:59 PM
Rep:126
Default Received mircophone/autodim mirror
OK y'all, I received my used mirror today, this mirror came from a parts place, they cut the wire at the roof line leaving the mirror connector intact. I posted a picture of the wire colors. They do not match the specs listed in this post from earlier. This mirror part number is the right one, it came from an 09. I would like to use this connector and extend the wires myself, saving me about $100 from buying the cable online. Thoughts on what wire goes to the radio using these wires? I have the plug that goes to the radio.
Old 11-08-2012, 11:08 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
You may want to pay attention to the connector and pinouts given in post #2 and not worry with the colors of the wires. Wire colors can change but the pinouts should be the same.
Attachment 31555
Old 11-08-2012, 05:32 PM
Rep:126
Exclamation
I found this on the techauthorityonlinedemo.extra.chrysler.com site: https://techauthorityonlinedemo.extr...ew/classic.htm
I put in the Laramie edition as when I put in the BigHorn (SLT) edition, the module does not come up.
Now, the question is, is this site correct?
Old 11-08-2012, 07:22 PM
astroman54's Avatar
Rep:52
The diagram you have here looks to be the wiring for the microphones to the RER or the RHR radios. If you have any other radios, this wiring diagram will not be correct. Plus, this only covers the microphones, it does not cover the rest of the signals needed to properly wire the mirror, like +12V, Ground, Reverse wire, etc..
Andy
Andy
