Old 10-30-2012, 09:06 PM
Ramadian's Avatar
Ramadian Ramadian is offline
Vehicle: 2012 Ram 1500 Sport
Rep:17
Ramadian is on a distinguished road
Default Why a catch can?
Im new to he new rams....
Soooooo, can any one tell me the full deal as to why lots of people are doing the catch can mod?
Old 10-30-2012, 09:30 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Because it is cheap insurance by keeping your top end nice and clean. Just check out this thread, it has all been explained in there. http://www.ramforumz.com/showthread....ighlight=catch
Old 10-30-2012, 09:55 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
heres a good one too. after the first few posts
2005 Dodge NSRT-4
Old 10-30-2012, 10:59 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
it keeps oil out of your air filter housing and looks awsome
Old 10-30-2012, 11:05 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^ Close but not quite the air filter housing, actually it's the hose that goes just under the throttle body that comes from the PCV valve.
Old 10-31-2012, 07:58 AM
Grubrunner's Avatar
Rep:3883
Your second reason is why eight out of ten people have them.....
Kudos for being honest.
Grub out!
Old 11-01-2012, 05:17 PM
1ofakind's Avatar
1ofakind 1ofakind is offline
Vehicle: 2014 Ram 1500
Color: maximum steel
Rep:13
1ofakind is on a distinguished road
You will see why everyone is Doing it once you experience how much oil you get in the catch can. I put 1000kms on since I put y catch can on and it is half full... That is a lot of oil to be putting on your top end
6k Lows & Fogs / 40" SR / 308's / 325 60 20's / Husky Mats / 5% Tint / Debadged / Wrapped Dash / 2" Level / Ez-Down /
Old 11-03-2012, 05:55 AM
Ramadian's Avatar
Rep:17
So once its full you just pour it out?
Im a little worried now that i just bought a $60,000 truck that loses oil?!
Old 11-03-2012, 03:23 PM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
im new to this catch can thing. can they be put on the 4.7?
Lift 'em high because fat girls can't climb!
Old 11-03-2012, 04:13 PM
Rep:2657
every engine needs to breathe,
both down in the crank case & up in the combustion chamber
the combustion chamber is basically above the pistons, where your spark plugs, valves, intake & exhaust manifolds are
Fuel & air goes into the intake manifold, then to the top of the pistons, the spark plug fires, the exhaust manifold takes away the unused pressure
below the pistons, there is the crank case
there is nothing there but a load of parts moving around in oil ( there is no gas or air in the crank case ), it is suppose to be a separate sealed off area from the combustion chamber, but it is only separated completely by pistons, piston rings, hydraulic lifters, & seals on the valves. So with all these parts moving, there is some PRESSURE in the crankcase, because of blow by.
That pressure builds up & it has no where to go
old engines crankcases had a ROAD DRAFT TUBE that allowed the crankcase to release that pressure build up, the excess pressure went down a tube & dumped just in back of the engine on to the road.
Along came the SMOG people, they said that we could no longer dump these oil fumes onto the road, so PVC smog laws were made.
They said that we had to reuse these oil fumes, basically recycle them through the engine again
So now we are putting oil fumes into the combustion chamber, where oil is not suppose to be,
so someone invented a catch can, it allows the dirty air to pass through the filter in the top of the catch can, but the oil in the fumes are trapped & drop into the bottom of the catch can.
all we have to do is dump the contents when we change our oil
look at this drawing, it shows how the road draft tube used to function
http://lh5.ggpht.com/_Ii1ukGkfijY/Sq..._image0023.jpg
