Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-30-2012, 09:17 PM
RamRepair23 RamRepair23 is offline
Vehicle: 1998 Dodge ram 3500
Trim Level: none
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
RamRepair23 is on a distinguished road
Default 5th gear gone
Driving down the road in 5th today and all of a sudden I lost power to my rear wheels. I have read that this may have to do with a nut on the back of the transmission. Dose any body have any experience with this?
Old 10-31-2012, 07:32 PM
Wantedwarrior102's Avatar
Wantedwarrior102 Wantedwarrior102 is offline
Vehicle: 1999/2002 Dodge Ram 2500
Color: Black/Blue
Rep:27
Wantedwarrior102 is on a distinguished road
I have never had the issue but it is a common problem. I hear there is an updated nut through chrysler and some even go as far as putting a small tack weld to keep if from happening. I think you can do it with the transmission in the truck just remove the transfer case and tail shaft housing. Hope it all works out
Old 12-04-2012, 05:23 PM
epyle3 epyle3 is offline
Vehicle: 1999 ram 2500
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
epyle3 is on a distinguished road
Default 5th gear tach weld
My 99' cummins 5 spd with 230000 miles required a weld to secure the nut. third party inventors offer a "permanent" secure but cost approx $130 ?? the job can be done in an hour but I paid the quoted 3 hr rate plus fluid .. $450 ... just drop drive shaft, drain and unbolt back of case ,, bolt is on top. I now wonder if I should have redone other bearings??? edp
