Dodge Ram 05 fuel pump issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-31-2012, 08:29 AM
sassy1217 sassy1217 is offline
Vehicle: 2005 Dodge Ram 1500
Color: Blue
sassy1217 is on a distinguished road
Default Dodge Ram 05 fuel pump issue
Our Ram died while driving, had it towed back to the house. It will start, but only for a few seconds.Tested the battery, definitely not the problem. And, it's not giving any error codes at at all. Dropped the fuel tank down and disconnected it. It is trickling and making a grinding noise. Does this sound like the fuel pump needs to be replaced? Just checking before I spend 199.00 for the part to replace it. Thank you.
Old 10-31-2012, 11:11 AM
07TORAMU's Avatar
07TORAMU 07TORAMU is offline
Vehicle: 2007 DODGE RAM 1500
Trim Level: BIG HORN
Color: blue
Rep:13
07TORAMU is on a distinguished road
From what you have said,i would do this put ur ear close to tank(fuel ) have someone turn key in the on position do not start,dodge has a steady noise for fuel.let me know how it sounds,how many miles on truck? Have u replaced it yet ever? What about ur fuel filter if and when did you replace? Also have you tested fuel pressure? Let me know
07TORAMU's Avatar
Color: blue
Rep:13
Hi i'm 07 to ram u
welcome to the forum.i am a a.s.e. Tech if you need help one of us can do are best to (asst) you.also please be sure to check out the store for great stickers,shirts and all your auto needs...are vendors are great to i my self highley recommend (autoanything) thank you!!!!!!!!!!!!!!!!!
Old 10-31-2012, 11:59 AM
Color: Blue
Ive remove the bed of the truck to access the pump. ive not done any work to the truck since buying it new. The fuel filter has not been replaced. The truck has about 176,000 miles on it. The fuel pump makes a kind of grinding noise not the highpitch sound that a fuel pump makes. I disconnected the fuel line to see if it would pump fuel when the switch was turn on. It didnt come out with any pressure just kind of dribbled out. The truck will only start for a couple of seconds and there is not much if any pressure at the fuel rails
Old 10-31-2012, 01:34 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Sounds like the pump to me. It should be pressurizing the fuel rail to something like 50 psi(?) so it should be shooting out of there.
Old 10-31-2012, 01:38 PM
Resident Technician
Rep:1915
This could also be a security issue. If the WCM has a problem, it won't recognize the key and will allow the truck to start and run for about 3 seconds or so and then kill the engine.
Old 10-31-2012, 01:54 PM
Color: Blue
RamTech are talking about a chip in the key. I don,t think it has one.
Old 10-31-2012, 01:57 PM
Resident Technician
Rep:1915
What does your key look like? Is is black and concave at the center or gray and convex at the center?
Old 10-31-2012, 02:08 PM
Color: Blue
its black and concave. does not look like there is anyplace for a chip.
Old 10-31-2012, 10:10 PM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Black keys are the ones without SKIM(security). From everything described, it's most likely the pump. Grinding sound with only a little dribble is not normal for the fuel pump.
