Old 10-31-2012, 01:49 PM
tteachman tteachman is offline
tteachman is on a distinguished road
Default integrated brake controller wiring
I have purchased and rec'd the integrated brake controller for my 2010 Dodge Ram and went to install when I noticed I do not have both plugs for the controller. I have done a lot of research and have wired the B Connector myself but every time I connect the B3 (Fused ignition Run/Start control output) to the pink/light green stripe wire the truck will not start. Any help would greatly be appreciated. I cannot return the inegrated brake controller and do not want to be out $200!
Old 11-01-2012, 03:09 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
It will work on just 1 plug. The little plug is just for evic. If you have evic you would still need to get it flashed for it to show up.
Old 01-09-2013, 02:50 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
My factory controller died so I am installing an aftermarket one. If any of you that installed the Dodge controller and still have the dash piece that you had to take out let me know. I need the tan color. Shoot me a PM.
brake controller, trailer brakes wire, trailer connector
