Old 11-01-2012, 07:35 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
A stock RT ram runs ~14.5
umm no your wrong my stock r/t ran a 13.8
Old 11-01-2012, 09:07 PM
Zedison's Avatar
Zedison Zedison is offline
Vehicle: 2012 dodge ram r/t
Trim Level: R/t
Rep:14
Zedison is on a distinguished road
I run 13.8s in my stock R/T also and you do have a chance against hemi chargers amd challengers they only claim 370hp and weigh about 400 less which gives you the advantage but they r tuned differently i stay door to door with the 300c the challenger charger and hemi jeeps now srt8s will spank you but not the normal hemis
2/4belltech drop,mufflex muffler delete,debadged,front,rear sway bars,adjustable trac bar,5%tint,87mm moes throttle body trinity with hemifever tune afe stage 2 cold air and long tubes on the bottle with 6.1 intake on the way
Old 11-01-2012, 09:24 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Ok well my buddy was running 14.6 consistently in 3 passes when he went. Bone stock down to the air filter and tires. And we are at sea level. It was hot though, but still nearly a second difference....doesn't make sense.
Sean
Old 11-01-2012, 09:32 PM
Zedison's Avatar
Trim Level: R/t
Rep:14
U also have to think of the driver, traction and how the truck has been drivin i have had mine for about 6 months have 14,000 miles and drive the livin crap out of it i dont baby it one bit and i also live at sea level here in texas not tryin to say your friend didnt run that theres just alot of factors to concider
Old 11-01-2012, 10:14 PM
snrusnak's Avatar
Rep:1385
Yeah I believe it. He pretty much beats the hell out his truck, his gas pedal only has two positions lol. On of Off. It was nearly 100 deg F out, that's probably why... I was running 16.2 at the same time. Normally that'd be more like mid to high 15's. So he's probably good for low 14's.
Depending on conditions...
Sean
Old 11-01-2012, 10:23 PM
Zedison's Avatar
Trim Level: R/t
Rep:14
That is true he sounds like me and conditions do play a big part of it cause i run differemt time at 2 tracks that r 90 miles apart and my truck hates the heat also
Old 11-02-2012, 02:10 AM
SnoylCC5's Avatar
SnoylCC5 SnoylCC5 is offline
Vehicle: 2007 Dodge Ram
Rep:139
you should have him, i think you would atleast
Old 11-02-2012, 03:23 PM
Jram302's Avatar
Jram302 Jram302 is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Rep:29
Jram302 is on a distinguished road
On stock wheels? How are you getting traction? I have never taken my truck to the track because on the street my tires dont stick to good so i never bothered taking it to baytown for a base run.
Old 11-02-2012, 03:30 PM
Jram302's Avatar
Trim Level: R/T
Rep:29
Also i've ran against an r/t chally from about a 20 roll and put a couple car lengths on him by the time i capped out at 105. Didnt know if it was automatic/stick or if he fell asleep at the wheel when we punched it. Then later that same day i lost to an s2k by about half a car from 20 roll to 105, at about 80mph the s2k came from my back tire and then put the half car dist between us.
Old 11-02-2012, 03:50 PM
BrandonMski's Avatar
BrandonMski BrandonMski is offline
Vehicle: 2006 Dodge Ram 3500
Rep:24
BrandonMski is on a distinguished road
Threads like this just remind me how slow my truck really is lol all the most reason to build that blown 408 stroker I've been wanting to build. Then I might be able to keep up with some of you guys haha
2000 Dodge Ram 1500 Sport 4x4 - 5" lift, 36" tires, CIA, exhaust, CB radio, bed liner, undercoated, and more
2006 Dodge Ram 3500 Laramie 4x4 - trans temp, EGT, boost gauges, 5" exhaust, CIA, Fass 95GPH
