jaw jaring wheel hop - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 11-01-2012, 10:52 PM
Nitro1 Nitro1 is offline
Vehicle: 96 dodge ram 3500. 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Nitro1 is on a distinguished road
Default jaw jaring wheel hop
Hi all! I have me a issue with my 96 3500 4x4 diesel. when i hit a good pot hole doing 40- 70 mph i get this nasty wheel hop, like there are no shocks.its so violent, it wont stop unless i pull over. Yet i just replaced the shocks with monroe gas magnums. the old girl has 120 thou on her. You think the springs went soft on me?? I have noticed the front end bottoming out on me when you hit a good bump. Also front driver side wheel very chopped. Thanks for your time Nitro 1
Old 11-03-2012, 09:00 AM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Sounds like your getting the death wobble. I would check your front end for play. the most common problem is the track bar, that's usually the fix on most of the trucks.
Old 11-03-2012, 11:25 AM
Thanks for the reply. How do you check front end play. lift up truck and check track bar for play? There is also a dampener looks like a shock mounted horizontal? When you say say death wobble does the truck bounce up and down or left to right?
Old 11-10-2012, 05:06 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
To check the track bar, have someone turn the steering wheel while you observe the ball joint end of the bar at the frame. If theres a lot of movement, it's toast. If you can grab the bar by hand and and feel movement, same thing. This can cause lateral or vertical death wobble.
Tie rods can be checked by the same method, and sometimes I'll pry against them with a prybar to see if I see movement in the ball sockets. Ball joints are allowed .125 freeplay any more than that and they are shot.
Cupped or internally damaged tires can cause this... worn out control arm bushings, etc.
