Old 11-02-2012, 02:16 PM
ssxrnr ssxrnr is offline
Vehicle: 2012 Dodge Ram
Trim Level: R/T
ssxrnr is on a distinguished road
Default New Owner Suspension Advice Please
Hello I just purchased a 2012 R/T and already have a Ground Force 2/3 lowering kit to install. If or when I add Helwig sway bars should I also install the adjustable end links? I also plan on installing an pan hard bar from spohn?
Old 11-03-2012, 08:27 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
The Hellwig bars come with non-adjustable links for the rear, you re-use the OEM links up front. You'll use the rear links with the drop for sure.
Old 11-03-2012, 09:27 PM
Trim Level: R/T
I was looking for your response. I am going to add the pan hard bar from Spohn. Another member mention a relocation bracket for that as well?
