Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 11-03-2012, 01:58 AM
Tubbs1 Tubbs1 is offline
Vehicle: 2012 RAM Hemi Crew Cab
Trim Level: RT
Color: Deep Cherry Red
Rep:31
Tubbs1 is on a distinguished road
Default The numbers are in!!!!!
Well folks I finally went to the track with the ram last night and here are the numbers
Air Temp - 68
Humidity- 52%
Well my first run out of the gate was 15.14 second 15.04 third 15.01 fourth 15.02.
So all in all it is a 15 second full size four door truck. I think we can do better any ideas ?
Old 11-03-2012, 03:13 AM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
You can do better! What mods do you have?
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 11-03-2012, 04:08 AM
Rep:2705
manually shift your automatic transmission
turn on Tow/haul
start in 2nd gear
do NOT shift into Drive
Old 11-03-2012, 04:20 AM
mturner071204's Avatar
mturner071204 mturner071204 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Color: True Blue Metallic
mturner071204 is on a distinguished road
Was everything electrical off in/on (headlights, ect.) the truck, Was the cover on or off? These little things can add up alot.
Old 11-03-2012, 10:35 AM
Trim Level: RT
Rep:31
Well folks here is the vehicle break down, I currently have a 4" velocity style CAI, JBA ceramic shorty headers Y pipe delete running true duels to 14 magnaflows withe the stock 2.75 pipes out the back. Its kind of hodge podged but it works for now. As for the passes the head lights were on the tailgate was up,I ran the .01 and the ,04,02 in ERS and the .14 in eco mode I guess is what you could call it. With traction control on, Honestly I need a tuner to break into the 14's I think but I will take and advice and or suggestions that you all have !!!. Also keep this in mind the first time I ran it she was straight stock pulling 17.87,17.77, and 17.75. I know they say that in the hands of a pro it should be able to pull a 16 stock but I am not a pro !!! hahaha.
Old 11-04-2012, 12:23 AM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
6000lb+/- big ol' 4 door truck running almost 14's with a not-so-big 345c.i. engine.....
Pretty darn good if you ask me!!!
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 11-04-2012, 04:52 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
old hp, we are the same age and remembering what a 350 engine would do in a truck 15 years ago. i find these time very impressive for what we drive.
Old 11-04-2012, 06:24 AM
Trim Level: RT
Rep:31
Well gentlemen thanks for the nod of approval. I plan on getting a tuner and hope to break into the 14's with it. the guys I went with kept telling me to stage the truck and everything else but I did not. so maybe it could be faster maybe not but I will keep bolting things on. outside of a tuner anything else that we can thing of to do ? Also one thing I did not put above I had about 400 lbs of sand bags in the back to help it stop from spinning off the line.
Old 11-04-2012, 07:00 PM
oldhp's Avatar
Color: WHITE
Rep:902
400LBS??? Every hundred pounds is a tenth of a second.
If you can launch it, it should run 4 tenths faster!!! You need some more passes so you can launch it without all the weight. 400LBS extra, your times are even more impressive! Maybe try leaving at 1000/1200RPM, pause and nail it. Every car/truck is different.
Good Luck!!! But you might get the dragrace bug...
How would you know?
Old 11-04-2012, 10:15 PM
Trim Level: RT
Rep:31
OldHP I have had the drag racing bug since I owned my nova. I know that when I ran it stock all it did was spin I just knew that the weight was the fastest fix to get her to grip. I dont know if the weight would or could take that much off. I saw another 2012 ram there single short box hemi, and he was running right there with me almost identical times and similar mods, he had single pipe to mufflex, no headers CAI. So at this piont its anyone's guess ya know.
