Old 08-10-2013, 02:03 PM
PatrickJ PatrickJ is offline
Vehicle: 2005 Ram SLT
Rep:19
PatrickJ is on a distinguished road
spent 90 minutes last evening washing my giant Ram in order to wax it but I ended up taking to long washing it that I was too tired and it was too dark out to wax it
Old 08-10-2013, 02:43 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Replacing my water pump. USPS was supposed to deliver my fan clutch today, but I guess it'll get here Monday. Priority 2 day shipping, my ass.
Edit: Ok, I guess they came back and delivered it. Weird because they delivered the mail early, then came back with a package.
Old 08-10-2013, 04:32 PM
EHT's Avatar
EHT EHT is offline
Vehicle: 2013 ram 1500 sport
EHT is on a distinguished road
Originally Posted by Chunkem View Post
Just replaced the factory CAI with a Mopar CAI.....
wow that look nice did you see any improvement and how much it cost??
thanks
Old 08-11-2013, 02:52 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Bung for Wideband welded to driver side down-pipe right after cat,
(ideally it should be pre-cat, but would have required exhaust removal and re-install)
Since I'm just using it for monitoring, not tuning, this will suffice for now...
Triple Pod Gauges finally plugged in and mounted, (Fuel Pressure, Boost and Wideband)
but now there's a crap load of wires to route through the firewall...
Some connector ends could be disassembled, thanks to my bud having the right tool
But others had to be cut and re-soldered after feeding them through...PITA!
I took pic's of the connector ends that were too large to feed through my firewall holes that were drilled for two small grommets.
I used color coded tape on the wire bundles so I would know which gauge they came from
since the boost and fuel pressure had the same colored wires.
power, ground and illumination... check, that was the only easy part I love Red, Black and White LOL!!
Map sensor for Boost gauge mounted to a custom made bracket (Thanks' Brad!)
bolted to the bracket that once held the engine cover prong beside the oil spout.
Upper left is the T fitting to the vacuum line, that leads to the boost gauge MAP sensor
I guess I could have taken a pic before install, all sensor connections are under and to the side.
Wideband connector plugged in and functional too,
But still have yet to find a good place to tap the fuel line for the fuel pressure sensor.
There's still a bunch of extra loose wires for other alternate gauge Pro-Control functions,
Those can wait for now after farting around all afternoon I called it a day.
Just playing with the gauge high/low warning levels and colors for each setting now...
Old 08-11-2013, 08:36 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
B.R.H.......nice looking work buddy. Those gauges look perfect and professional...thanks for sharing that
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 08-11-2013, 08:46 PM
Rep:554
I actually mounted them a couple weeks ago, 5 minute job for a trial fitting
...and just got around to wiring them up with sensors to actually work, that took almost 5 hours
couple more pics ...
all gauges and pod are from Auto Meter
Old 08-13-2013, 11:07 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
Originally Posted by arietem View Post
Ok, this has got to be a bit unique.
I got a few professional photos taken of me and the truck.
Then I hired a professional painter to do a painting of me and my truck.
I call it: Distinctively RAM.
Hope you like it ...
I just love it - 24"x 36" in Acrylic.
I'm posting the art portrait and the original photo ! -
May have an other done !
I notice that you had the side done with the Hemi logo! Hahahahaha.....
Great job, that is definitely a first!
Old 08-14-2013, 12:34 PM
mwarren2013Ram mwarren2013Ram is offline
Vehicle: 2013 Dodge Ram1500 2wd express
Rep:25
mwarren2013Ram is on a distinguished road
Default Window tint
Had my front windows tinted to 30% and the top of the windshield to match the rear glass.
Old 08-14-2013, 01:30 PM
cjgerson's Avatar
cjgerson cjgerson is offline
Vehicle: 2013 RAM 1500
Trim Level: Laramie Limited
Color: Black Clear Coat
Rep:65
cjgerson will become famous soon enough
Over the weekend installed a Retraxone tonneau and Bed Rug mat. Absolutely love the tonneau. The black matches my black truck almost perfect.
RetraxOne Tonneau cover, DeeZee tailgate assist, Line-X premium bed liner, Bed Rug Bed Mat, Freedom Tailgate seal, Cabin Air filter, aFe Magnum FORCE Air Intake System, Muffllex DOD18M, AVS Aeroskin Hood Shield, Craven Stubby Antenna, Tinted Windows, AVS In-Channel Vent-visors, AMP Research Black Bed Xtender HD, Hypertech Interceptor, E&G Classics - Polished Heavy Mesh Bumper Grille insert , Lamin-X 3rd brake and fog lights, E&G Classics Polished Heavy Mesh Bumper Grille Insert
Old 08-14-2013, 01:42 PM
RamRod55's Avatar
RamRod55 RamRod55 is offline
Vehicle: 2010 Ram 1500 4x4 Crew
Trim Level: Big horn
Rep:26
RamRod55 is on a distinguished road
Swapped out the old muffler with a flowmaster 40 series muffler welded right into the stock dual outs and man do I loveeee driving around now.
