46re Throttle + Shift Lever Removal Help??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-03-2012, 09:56 PM
Metallifan Metallifan is offline
Vehicle: 2001 Dodge Ram SLT
Trim Level: SLT Laraime
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:28
Metallifan is on a distinguished road
Default 46re Throttle + Shift Lever Removal Help???
I'm trying to drop my 46re valve body while it's in the truck, but I cannot for the life of me get the freaking throttle + shift levers off their shaft outside the case. I did it no problem with one that was off the truck. I've taken both bolts out. Pryed for nearly 20 minutes and moved them maybe 1/8". What am I doing wrong??????
Old 11-04-2012, 12:52 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Well nothing they should come off, most likely they are a little rusted. Don't pry on them too hard, what you can try to do is clean up the area as best as you can and heat up the levers a little, don't get too hot because you will melt the seal. Try maybe spreading the two halfs of the lever apart.
Old 11-04-2012, 01:08 PM
Rep:2962
Try spraying some PB BLASTER on it, let it soak in for say 15 minutes
then try again
It is right next to the WD-40 & Liquid Wrench on the store shelf
Old 11-04-2012, 01:58 PM
ramvan2500's Avatar
Rep:141
then try again
It might be rust and stuff but sometimes actually many times the lever is over tightened and it ends up being very tight on the shaft so spreading the lever apart helps to loosen it. I would be careful with PB BLASTER on rubber because it dries it out.
Old 11-05-2012, 10:40 PM
Rep:28
Thanks for the tips, guys. I got it out about an hour after posting that. Just had to pry it in the sweet spot.
Old 11-05-2012, 10:54 PM
ramvan2500's Avatar
Rep:141
glad to hear you got it off, just be careful because some of them are obsolete.
